oxy Posted May 6, 2010 Share Posted May 6, 2010 Hi there, I just got an harmony cart and is the best thing since the creation of the universe! Previously my only atari (a jr) have been modded to have a 1/4 jack output to use the synthcart with my music equipment. This was done where the video signal was so I havent use it as a game console for years. I also have a supercharger that needed to change the 1/8 jack. However I never use it after fix it. I remember it showed the menu on the jr. Well I specifically got an 7800 to use with the harmony, after checking here in this forum that works. Cool! But I made the mistake to test all my carts..... Including the supercharger. So did it broke it? Can I fix it? Thanks Quote Link to comment Share on other sites More sharing options...
Underball Posted May 6, 2010 Share Posted May 6, 2010 Hi there, I just got an harmony cart and is the best thing since the creation of the universe! Previously my only atari (a jr) have been modded to have a 1/4 jack output to use the synthcart with my music equipment. This was done where the video signal was so I havent use it as a game console for years. I also have a supercharger that needed to change the 1/8 jack. However I never use it after fix it. I remember it showed the menu on the jr. Well I specifically got an 7800 to use with the harmony, after checking here in this forum that works. Cool! But I made the mistake to test all my carts..... Including the supercharger. So did it broke it? Can I fix it? Thanks did it stop working? as far as I know, the Supercharger might be incompatible with certain 7800 Motherboard revisions, but it doesn't kill them as far as I know. Quote Link to comment Share on other sites More sharing options...
oxy Posted May 6, 2010 Author Share Posted May 6, 2010 (edited) Thanks for your reply. Here is where I read that they kill it: Superchargers being fried/blown by 7800s See first reply. I have not test it with the 2600 JR as I need to enable the RF out again. Anybody can confirm? Edited May 6, 2010 by oxy Quote Link to comment Share on other sites More sharing options...
+Mitch Posted May 7, 2010 Share Posted May 7, 2010 So what is not working, the 7800 or the supercharger? Many 7800s are not compatible with the supercharger but the part about it killing them seems to be more urban legend. Mitch Quote Link to comment Share on other sites More sharing options...
oxy Posted May 10, 2010 Author Share Posted May 10, 2010 Ok I tested the supercharger on the 2600jr after enabling the RF output again. It works fine!! I guess mitch is right about the urban legend. The 7800 works ok. Thanks for your replies guys So what is not working, the 7800 or the supercharger? Many 7800s are not compatible with the supercharger but the part about it killing them seems to be more urban legend. Mitch Quote Link to comment Share on other sites More sharing options...
supercat Posted May 10, 2010 Share Posted May 10, 2010 So what is not working, the 7800 or the supercharger? Many 7800s are not compatible with the supercharger but the part about it killing them seems to be more urban legend. If a cartridge expects the 6507 to be performing a read when it is actually performing a write, both the processor and cartridge will simultaneously attempt to put different data on the bus simultaneously, a situation called bus contention. If bus contention happens occasionally, it is unlikely to damage anything. If bus contention happened sufficiently often for a sufficient time, however, it could cause parts to overheat and fail. The exact values of 'sufficiently often' and 'sufficient time' are dependent upon many factors. I don't think it's possible for the 6507 to try to write to cartridge space more than 1/3 of the time (two cycles every six, using INC $nnnn) and given that the first byte of written data would match the read data, in most scenarios it's unlikely that it could write contentious data more than 1/4 of the time (one cycle every four, using STA $xxxx). I would guess that even in worst-case scenarios involving a cart trying to output $FF when the 6507 was outputting $00, it's unlikely that the 6507 or cart would be quickly damaged, but they could heat up enough to cause accelerated wear. Quote Link to comment Share on other sites More sharing options...
