CV Gus Posted May 13, 2010 Share Posted May 13, 2010 I need to order at least two Normally CLOSED relay switches. Radio Shack no longer has them, I'm afraid. I need them to complete my latest 5200 project. Can anyone here recommend a place where I can get them? They must be low voltage, by the way- the lower the better. Thanks. Quote Link to comment Share on other sites More sharing options...
A.J. Franzman Posted May 13, 2010 Share Posted May 13, 2010 (edited) Double-throw relays are more common than purely NC relays. Double-throw means it's both normally open and normally closed -- there's a Common terminal, an NO terminal, and an NC terminal for each "pole" of the relay (SPDT = single pole, double throw; DPDT = double pole, double throw; 3PDT = three pole; etc.) Edited May 13, 2010 by A.J. Franzman Quote Link to comment Share on other sites More sharing options...
tetrode kink Posted May 14, 2010 Share Posted May 14, 2010 Try Mouser and Digi-Key. I don't know if they have relays, but they have everything else so it's worth a look. -tet Quote Link to comment Share on other sites More sharing options...
CV Gus Posted May 15, 2010 Author Share Posted May 15, 2010 Double-throw relays are more common than purely NC relays. Double-throw means it's both normally open and normally closed -- there's a Common terminal, an NO terminal, and an NC terminal for each "pole" of the relay (SPDT = single pole, double throw; DPDT = double pole, double throw; 3PDT = three pole; etc.) I tried that, too- no luck. My 2000 catalog, sad to say, is HOPELESSLY outdated- I kept it for the part #. If you know where I can get a SPDT or even a DPDT switch, or just a NC switch, any of it will do. But it must be a relay that will switch from one to the other when a small current is passed through the coil. Quote Link to comment Share on other sites More sharing options...
zylon Posted May 28, 2010 Share Posted May 28, 2010 (edited) only ones I have at work are 24vDC and 16vDC. I got one for someone to fix their TV once. You can possibly use a horn relay from an old car. Edited May 28, 2010 by zylon Quote Link to comment Share on other sites More sharing options...
hex65000 Posted June 4, 2010 Share Posted June 4, 2010 Another good source is Allied Electronics for all your coil needs... http://www.alliedelec.com/sensors-switches-relays/ Hex. [ Had at least one success today... ] Quote Link to comment Share on other sites More sharing options...
Gorf Posted June 6, 2010 Share Posted June 6, 2010 Of course you can also use a seperate voltage supply for the needed 12/16/24 volt relays. Try goggle with this link... http://www.google.com/#hl=en&rlz=1R2ADFA_enUS338&q=5+vdc+relay&aq=1&aqi=g-s1g3g-s3g2g-ms1&aql=&oq=5+vdc&gs_rfai=&fp=8f72db810780d33e ...all sorts of options for 5 vdc relays. Quote Link to comment Share on other sites More sharing options...
