Galvatron Posted May 30, 2010 Share Posted May 30, 2010 I just bought a 5200 on ebay with ten games. It's the four port model. When I hooked it up it would not power on. After some looking at part numbers and voltages I discovered that they gave me an ac adapter from an atari 400/800 computer which outputs AC instead of DC which is what it is supposed to take. Tested the ac adapter anyway and it doesn't even reach 9 volts ac but only 1 volt. Is there any alternate power supply I can use to test the system to make sure it works? Quote Link to comment Share on other sites More sharing options...
Koopa64 Posted May 30, 2010 Share Posted May 30, 2010 How many amps does the 5200 take? Quote Link to comment Share on other sites More sharing options...
+Mitch Posted May 30, 2010 Share Posted May 30, 2010 Normally that power supply would have fried the 5200 but if it's already dead then your 5200 is likely still fine. You will just need to find the proper power supply. Mitch Quote Link to comment Share on other sites More sharing options...
bohoki Posted May 30, 2010 Share Posted May 30, 2010 Normally that power supply would have fried the 5200 but if it's already dead then your 5200 is likely still fine. You will just need to find the proper power supply. Mitch i'm thinking maybe the system is fine and the power supply is just bad i think the switchbox wants 9-11 dc volts at 1500mA a 4 port 5200 is a powerhog the system has good voltage regulators so its very forgiving with 9vac voltage going to the regulator it wouldn't have had enough voltage i think its diodes would only see half the switchbox may be jammed as well are you getting the light on "power on" Quote Link to comment Share on other sites More sharing options...
NoahsMyBro Posted May 30, 2010 Share Posted May 30, 2010 *IF* the system is in fact fried, it is repairable if you're interested in putting in time, effort, and a little bit of money. A few years ago I received a 5200 that had undergone a similar experience - it was powered up from an Atari 400/800 AC Adapter, and several components on the motherboard were destroyed. I managed to repair the system with a lot of help from folks on the internet, and I can probably find the discussion and photos that helped me get everything back together again if you want them. Just let me know. Quote Link to comment Share on other sites More sharing options...
atariksi Posted May 31, 2010 Share Posted May 31, 2010 How many amps does the 5200 take? You don't have to have exact amperage as long as the minimum is met like 2Amps. There was another thread recently about using IBM Thinkpad power supply of 4.5Amps and 16V with the A5200. That worked fine for me although it's more than A5200 needs. Quote Link to comment Share on other sites More sharing options...
Galvatron Posted June 1, 2010 Author Share Posted June 1, 2010 Thanks for the help guys. No power light ever came on, I informed the guy on ebay I got it from waht the part number for the ac adapter was. He'll hopefully send it soon. I just want to play Pacman. ooh ADD. Just cross my fingers and hope the proper ac adapter allows it to work! I got some good games I want to play. Quote Link to comment Share on other sites More sharing options...
Galvatron Posted June 6, 2010 Author Share Posted June 6, 2010 I got the power supply yesterday and the system worked for a few seconds and then the switchbox clicked and there was no video. The system was still on though. I think the ac damaged the switchbox but not the system. Quote Link to comment Share on other sites More sharing options...
atariksi Posted June 6, 2010 Share Posted June 6, 2010 I got the power supply yesterday and the system worked for a few seconds and then the switchbox clicked and there was no video. The system was still on though. I think the ac damaged the switchbox but not the system. What's the adapter spec that you used? When it turned on, it showed working audio/video? Quote Link to comment Share on other sites More sharing options...
Galvatron Posted June 6, 2010 Author Share Posted June 6, 2010 It puts off around 14 volts which should be regulating properly. It is part number c018187 as listed in the FAQ. Audio and video did work fine for a few seconds until the switchbox clicked. I noticed on the board that there is a RCA jack internally. Does it also output rf? Quote Link to comment Share on other sites More sharing options...
+Mitch Posted June 6, 2010 Share Posted June 6, 2010 The 5200 auto-switchbox is known to fail like that. It's probably fixable if you're decent at soldering. I don't think you want to use the RF connector that's inside the system, it's still got the power voltage going through it. Quote Link to comment Share on other sites More sharing options...
Galvatron Posted June 6, 2010 Author Share Posted June 6, 2010 The eBay guy is getting a new switch sent off. Out of the ten games I got eight I really wanted and the other two I haven't played before. I hope it works. Quote Link to comment Share on other sites More sharing options...
Syntaxerror999 Posted June 8, 2010 Share Posted June 8, 2010 I just bought a 5200 on ebay with ten games. It's the four port model. When I hooked it up it would not power on. After some looking at part numbers and voltages I discovered that they gave me an ac adapter from an atari 400/800 computer which outputs AC instead of DC which is what it is supposed to take. Tested the ac adapter anyway and it doesn't even reach 9 volts ac but only 1 volt. Is there any alternate power supply I can use to test the system to make sure it works? Heres a post I recently made. Hope it helps http://www.atariage.com/forums/topic/164217-field-service-manuals/ Quote Link to comment Share on other sites More sharing options...
Galvatron Posted June 9, 2010 Author Share Posted June 9, 2010 Yeaaaaay, the new switch works. Back to pacman and missle command! Quote Link to comment Share on other sites More sharing options...
