high voltage Posted June 28, 2010 Share Posted June 28, 2010 The French 7800 needs a multi standard TV as the RGB signal isn't the same as UK RGB. Can you be more specific about what is different? It's a PAL RGB signal so I'm not sure why it would need a special TV. As long as the TV has an RGB SCART socket it should work. Mitch The French TV standard is Secam, not PAL Quote Link to comment Share on other sites More sharing options...
Sub(Function(:)) Posted June 28, 2010 Share Posted June 28, 2010 True, but PAL, SECAM and NTSC are all broadcast TV standards. We are talking about SCART RGB interface here. PAL and SECAM units both refresh at 50Hz so should be compatible. The NTSC unit refresh rate is 60Hz, so will cause timing problems on other units, and vice-versa. Quote Link to comment Share on other sites More sharing options...
mimo Posted June 28, 2010 Share Posted June 28, 2010 7800 SECAM is a miss description, they are PAL units Quote Link to comment Share on other sites More sharing options...
