Nats46 Posted June 3, 2010 Share Posted June 3, 2010 I had a topic on a different forum, and I haven't got a fixable answer yet. The 2600 has different colors on the screen when different games are in. They are mostly random, though. The cartridge in sometimes will determine the colors on the screen. There are often lines that are vertically coming down from the screen, and sometimes it shows a black screen. Please help me! Quote Link to comment Share on other sites More sharing options...
BDW Posted June 16, 2010 Share Posted June 16, 2010 I had a topic on a different forum, and I haven't got a fixable answer yet. The 2600 has different colors on the screen when different games are in. They are mostly random, though. The cartridge in sometimes will determine the colors on the screen. There are often lines that are vertically coming down from the screen, and sometimes it shows a black screen. Please help me! Pictures, please! Quote Link to comment Share on other sites More sharing options...
A.J. Franzman Posted June 16, 2010 Share Posted June 16, 2010 Some problems just can't be diagnosed remotely. Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted June 17, 2010 Share Posted June 17, 2010 It appears it's not reading the cartridge *at all*. Powering up with no cartridge produces the same effect that is described. Quote Link to comment Share on other sites More sharing options...
pags35 Posted June 17, 2010 Share Posted June 17, 2010 I had a topic on a different forum, and I haven't got a fixable answer yet. The 2600 has different colors on the screen when different games are in. They are mostly random, though. The cartridge in sometimes will determine the colors on the screen. There are often lines that are vertically coming down from the screen, and sometimes it shows a black screen. Please help me! Your best bet is to get a copy of the Atari 2600 Field Service Manual to try and diagnose the problem or give us some more information. It is difficult without pictures and being able to actually run test on the system. But the manual is pretty helpful if you take a look at it and have a basic multimeter for testing. Quote Link to comment Share on other sites More sharing options...
Cliff Friedel Posted June 17, 2010 Share Posted June 17, 2010 Not sure if you tried this, but I figured I would put down some basic things you could try. I would say the first thing you want to try is just to clean the carts and the port, then try them. Just take some 91% alcohol and a q-tip and, using a small flat screwdriver, push back the protector for the cart. Then clean the board edge. On the cartridge port itself, it is a little harder since you have to get inside of it to clean. Using something like a really thin screwdriver with some alcohol soaked cloth may work. Just make sure it doesn't end up staying in the port. Also, make sure it is dry before you turn on the machine. On another note, if you want to test the cartridges you have, you could always use another atari and try them in it. You could also take a known working cartridge from another collection and try it in yours too. That way, you can at least isolate where the problem is. Not sure how much this will help, but I figured I would put it up anyway. Quote Link to comment Share on other sites More sharing options...
A.J. Franzman Posted June 18, 2010 Share Posted June 18, 2010 Taking a stab in the dark, I would guess either a bad RIOT IC (or possibly installed backwards), or a bad chip select / A12 line, or power line to the cart port. Quote Link to comment Share on other sites More sharing options...
