Thelen Posted November 17, 2002 Share Posted November 17, 2002 I have a 21 inch monitor, with RGB in only (and vsync and hsync). Right now i have connected it with my pc, and it works good. Now i was thinking can i connect it to a XE/XL ? can i get rgb out of it, do i need vsync/hsync signals ? The monitor belonged to a apple macintosh, which only had RGB connected with it. Thelen Quote Link to comment Share on other sites More sharing options...
jindroush Posted November 19, 2002 Share Posted November 19, 2002 Now i was thinking can i connect it to a XE/XL ? can i get rgb out of it, do i need vsync/hsync signals ? There are no separated RGB/vsync/hsync signals in atari computers. Maximally S-Video. you've got to find some external device. Quote Link to comment Share on other sites More sharing options...
Curt Vendel Posted November 19, 2002 Share Posted November 19, 2002 I've tried several ways of doing this and there are a few composite to RGB converter chips to use.... I recall a few years back tinkering with a TMS4440 (I think).... the only problem you run into is that you end up loosing 8 lumes on the conversion and you don't get the full 256 color pallete, but it can be done.... Better solution, spend $59 and buy a Jam! or other Composite to VGA converter and get a set of speakers with a converter and Y adapter and plug your audio into them and you can use a VGA monitor with your 8bit Atari.... If you're willing to spend a few bucks ($499) this is well worth it, the new Samsung 15" LCD display, it has VGA, TV Tuner, Composite and Svideo inputs on it.... I have my PC, Sat TV, Laserdisc player/VCR and my Atari VCS hooked to it and its great to just switch back and forth... it even has a remote control.... Now, just cause you use a VGA monitor, don't be fooled into thinking your Atari screen will be super crisp and sharp like SVGA... the TV/Composite/and SVIDEO signals still have a washed out look on a VGA monitor just like a Composite. Its not the monitors fault, the Composite signal just has lowsy bandwidth and you're not going to get the same clarity as a pure VGA signal, its only a conversion. Curt Quote Link to comment Share on other sites More sharing options...
