MarlboroMan Posted June 25, 2010 Share Posted June 25, 2010 I don't guess that anyone would happen to have or know where I might be able to find a Wico Y Cable for use with the Wico joystick and key pad for the 5200? Quote Link to comment Share on other sites More sharing options...
bohoki Posted June 25, 2010 Share Posted June 25, 2010 I don't guess that anyone would happen to have or know where I might be able to find a Wico Y Cable for use with the Wico joystick and key pad for the 5200? the wico keypad plugs into the 5200 and the joystick plugs into the wico keypad if you have a wico joystick and need to plug it into the 5200 thats when you need the Y they are not that difficult to build once you round up some plugs 1 9 pin male, 1 15 pin male , 1 15 pin female i can walk you through building one there is no place that has piles of y cables the 5200 is kind of a limited market Quote Link to comment Share on other sites More sharing options...
MarlboroMan Posted June 25, 2010 Author Share Posted June 25, 2010 I don't guess that anyone would happen to have or know where I might be able to find a Wico Y Cable for use with the Wico joystick and key pad for the 5200? the wico keypad plugs into the 5200 and the joystick plugs into the wico keypad if you have a wico joystick and need to plug it into the 5200 thats when you need the Y they are not that difficult to build once you round up some plugs 1 9 pin male, 1 15 pin male , 1 15 pin female i can walk you through building one there is no place that has piles of y cables the 5200 is kind of a limited market So let me make sure I understand this. If you have the Wico 5200 Joystick and the Wico 5200 keypad, the keyboard plugs into the 5200 and the joystick plugs into the keypad, so you don't have any real need for the "Y-cable"? Quote Link to comment Share on other sites More sharing options...
atariksi Posted June 25, 2010 Share Posted June 25, 2010 I don't guess that anyone would happen to have or know where I might be able to find a Wico Y Cable for use with the Wico joystick and key pad for the 5200? the wico keypad plugs into the 5200 and the joystick plugs into the wico keypad if you have a wico joystick and need to plug it into the 5200 thats when you need the Y they are not that difficult to build once you round up some plugs 1 9 pin male, 1 15 pin male , 1 15 pin female i can walk you through building one there is no place that has piles of y cables the 5200 is kind of a limited market So let me make sure I understand this. If you have the Wico 5200 Joystick and the Wico 5200 keypad, the keyboard plugs into the 5200 and the joystick plugs into the keypad, so you don't have any real need for the "Y-cable"? Yeah, that's correct. However, there are more Wico joysticks available out there (going by Ebay observations) than Wico keypads and usually sold separately so most people end up needing the Y cable. Quote Link to comment Share on other sites More sharing options...
MarlboroMan Posted June 25, 2010 Author Share Posted June 25, 2010 I don't guess that anyone would happen to have or know where I might be able to find a Wico Y Cable for use with the Wico joystick and key pad for the 5200? the wico keypad plugs into the 5200 and the joystick plugs into the wico keypad if you have a wico joystick and need to plug it into the 5200 thats when you need the Y they are not that difficult to build once you round up some plugs 1 9 pin male, 1 15 pin male , 1 15 pin female i can walk you through building one there is no place that has piles of y cables the 5200 is kind of a limited market So let me make sure I understand this. If you have the Wico 5200 Joystick and the Wico 5200 keypad, the keyboard plugs into the 5200 and the joystick plugs into the keypad, so you don't have any real need for the "Y-cable"? Yeah, that's correct. However, there are more Wico joysticks available out there (going by Ebay observations) than Wico keypads and usually sold separately so most people end up needing the Y cable. OK - Gotcha! - That sounds good! Quote Link to comment Share on other sites More sharing options...
atariksi Posted June 25, 2010 Share Posted June 25, 2010 I don't guess that anyone would happen to have or know where I might be able to find a Wico Y Cable for use with the Wico joystick and key pad for the 5200? the wico keypad plugs into the 5200 and the joystick plugs into the wico keypad if you have a wico joystick and need to plug it into the 5200 thats when you need the Y they are not that difficult to build once you round up some plugs 1 9 pin male, 1 15 pin male , 1 15 pin female i can walk you through building one there is no place that has piles of y cables the 5200 is kind of a limited market So let me make sure I understand this. If you have the Wico 5200 Joystick and the Wico 5200 keypad, the keyboard plugs into the 5200 and the joystick plugs into the keypad, so you don't have any real need for the "Y-cable"? Yeah, that's correct. However, there are more Wico joysticks available out there (going by Ebay observations) than Wico keypads and usually sold separately so most people end up needing the Y cable. OK - Gotcha! - That sounds good! Hey, maybe someone in Hong Kong will clone one as I see a lot of stuff being cloned and selling for pennies on Ebay. Quote Link to comment Share on other sites More sharing options...
tz101 Posted July 11, 2010 Share Posted July 11, 2010 Would a PC "Y" cable work fine. It is the same pin configuration, is it not? Quote Link to comment Share on other sites More sharing options...
atariksi Posted July 12, 2010 Share Posted July 12, 2010 Would a PC "Y" cable work fine. It is the same pin configuration, is it not? I don't think pinouts are same as Wico joystick. Quote Link to comment Share on other sites More sharing options...
tz101 Posted July 12, 2010 Share Posted July 12, 2010 I have two I will test with my Wico sticks and report back... Quote Link to comment Share on other sites More sharing options...
