dukbrand Posted July 18, 2010 Share Posted July 18, 2010 When my four port is hooked up and running the tv buzzes, my current solution is to mute the tv as the video is fine, but I'd like to hear the game, any help? Quote Link to comment Share on other sites More sharing options...
atariksi Posted July 18, 2010 Share Posted July 18, 2010 When my four port is hooked up and running the tv buzzes, my current solution is to mute the tv as the video is fine, but I'd like to hear the game, any help? Could be grounding issues or power supply issues. Try different wall socket for the adapter-- maybe your mention of using the alternate RF connection on the motherboard may be causing it. Quote Link to comment Share on other sites More sharing options...
dukbrand Posted July 18, 2010 Author Share Posted July 18, 2010 When my four port is hooked up and running the tv buzzes, my current solution is to mute the tv as the video is fine, but I'd like to hear the game, any help? Could be grounding issues or power supply issues. Try different wall socket for the adapter-- maybe your mention of using the alternate RF connection on the motherboard may be causing it. The alt. hook up was on a four port i fried some time ago this is a different system I've run on two different tv's Quote Link to comment Share on other sites More sharing options...
atariksi Posted July 18, 2010 Share Posted July 18, 2010 When my four port is hooked up and running the tv buzzes, my current solution is to mute the tv as the video is fine, but I'd like to hear the game, any help? Could be grounding issues or power supply issues. Try different wall socket for the adapter-- maybe your mention of using the alternate RF connection on the motherboard may be causing it. The alt. hook up was on a four port i fried some time ago this is a different system I've run on two different tv's Try a different adapter or different wall socket (as I said). I had a 600XL that had an audio buzz and I moved it to another wall socket and it went away. Quote Link to comment Share on other sites More sharing options...
dukbrand Posted July 19, 2010 Author Share Posted July 19, 2010 When my four port is hooked up and running the tv buzzes, my current solution is to mute the tv as the video is fine, but I'd like to hear the game, any help? Could be grounding issues or power supply issues. Try different wall socket for the adapter-- maybe your mention of using the alternate RF connection on the motherboard may be causing it. The alt. hook up was on a four port i fried some time ago this is a different system I've run on two different tv's Try a different adapter or different wall socket (as I said). I had a 600XL that had an audio buzz and I moved it to another wall socket and it went away. I'll give that a try Quote Link to comment Share on other sites More sharing options...
