Madaracs Posted August 2, 2010 Share Posted August 2, 2010 Being that there is such a nicely sized homebrew community here, I was wondering if anyone has made an adapter that would allow you to play 8-bit Atari carts in a 5200 or is that just not possible? Quote Link to comment Share on other sites More sharing options...
GroovyBee Posted August 2, 2010 Share Posted August 2, 2010 I think that it would be far easier to do a software conversion for the different address map and controller input than fit an A8 into a plug in module for the cart slot. Quote Link to comment Share on other sites More sharing options...
Madaracs Posted August 2, 2010 Author Share Posted August 2, 2010 I think that it would be far easier to do a software conversion for the different address map and controller input than fit an A8 into a plug in module for the cart slot. I wonder if an emulator cart could be made. Though it seems a waste of time, really. And I didn't realize that the address map would be an issue. Quote Link to comment Share on other sites More sharing options...
kruuth Posted August 10, 2010 Share Posted August 10, 2010 Can't happen. If you had the code for the original 8 bit then you could port it pretty easily though. The registers are in different places. That, and assuming that there are no hardware specific issues, the 5200 is just an Atari 400 with maxed-out ram. Quote Link to comment Share on other sites More sharing options...
atariksi Posted August 10, 2010 Share Posted August 10, 2010 Can't happen. If you had the code for the original 8 bit then you could port it pretty easily though. The registers are in different places. That, and assuming that there are no hardware specific issues, the 5200 is just an Atari 400 with maxed-out ram. With some simple hardware modifications on A5200, you could map the GTIA so that it works at $C000 as well as $D000 and since ANTIC is already at $D400, putting a dual POKEY in 5200 so it's at $E800 and $D200 would solve most register location problems. But A400 also has a PIA and RAM expansion cards. Quote Link to comment Share on other sites More sharing options...
Greg2600 Posted August 11, 2010 Share Posted August 11, 2010 If you already had 8-bit carts, I'd say just use an 8-bit computer. You'd be able to use good joysticks, and if you had something in the XE's vintage, you can play games on par with the 7800. Quote Link to comment Share on other sites More sharing options...
Zoyx Posted August 11, 2010 Share Posted August 11, 2010 Yeah, just get a XEGS. Then you won't have to deal with the temperamental 5200 controllers. Quote Link to comment Share on other sites More sharing options...
eightbit Posted August 11, 2010 Share Posted August 11, 2010 But the 5200 is BIGGER, the carts are BIGGER. 80's test markets say bigger equals better value! Quote Link to comment Share on other sites More sharing options...
Madaracs Posted August 17, 2010 Author Share Posted August 17, 2010 But the 5200 is BIGGER, the carts are BIGGER. 80's test markets say bigger equals better value! And I suppose you'll also remind us that there is absolutely no where to store your controllers on an XEGS. I love my 5200 but I just thought it would be cool to be able to plop in an 8-bit cart. I'll probably just pony up and get an XEGS or another 8-bit machine. Quote Link to comment Share on other sites More sharing options...
