w1k Posted August 25, 2010 Share Posted August 25, 2010 hello, i need build this atmel programmer for programm sio2sd chip.. i need lpt cable? when i built it, where i connect other side? to sio2sd? Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted August 25, 2010 Share Posted August 25, 2010 (edited) It's your lucky day: You just need to wire the parallel cable to a six-pin female header and attach it to the male header on the board in the location and orientation shown in the picture. I built one exactly like this and it works perfectly. The oscillator and all other components in the diagram you posted are already on the SIO2SD board and the power is supplied through the SIO port. Edited August 25, 2010 by flashjazzcat 1 Quote Link to comment Share on other sites More sharing options...
w1k Posted August 25, 2010 Author Share Posted August 25, 2010 thanks, im lucky men on week my father look at it Quote Link to comment Share on other sites More sharing options...
w1k Posted August 29, 2010 Author Share Posted August 29, 2010 which program for this scheme can i use? avr atmel? Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted August 29, 2010 Share Posted August 29, 2010 AVRprgWin.zip 1 Quote Link to comment Share on other sites More sharing options...
w1k Posted August 29, 2010 Author Share Posted August 29, 2010 ok, so what next? only connect it to sio2sd? atari must be on power? or? Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted August 29, 2010 Share Posted August 29, 2010 Plug in the SIO2SD as normal. Connect the programming cable to the PC and to the header on the SIO2SD PCB. Now power on the Atari. Then run the software: it should say ISP detected, then you can calibrate it, etc... it's all quite simple, providing the cable works. 1 Quote Link to comment Share on other sites More sharing options...
w1k Posted March 19, 2011 Author Share Posted March 19, 2011 can i use this programator to flash any eprom chip? Quote Link to comment Share on other sites More sharing options...
Rybags Posted March 19, 2011 Share Posted March 19, 2011 (edited) No. This is only good for certain serially programmable types. The old EPROMs were parallel and generally needed higher than standard voltages for the programming process. On top of that, EPROM as opposed to EEPROM needs the UV erase process carried out first. Edited March 19, 2011 by Rybags Quote Link to comment Share on other sites More sharing options...
19Echo Posted December 30, 2012 Share Posted December 30, 2012 Old topic i know, but i cant seem to find a female header pin anywhere. Does anyone know where i could order one from? thanks Quote Link to comment Share on other sites More sharing options...
santosp Posted December 30, 2012 Share Posted December 30, 2012 http://rover.ebay.com/rover/1/711-53200-19255-0/1?icep_ff3=9&pub=5574883395&toolid=10001&campid=5336500554&customid=&icep_uq=idc+6+pin&icep_sellerId=&icep_ex_kw=&icep_sortBy=12&icep_catId=&icep_minPrice=&icep_maxPrice=&ipn=psmain&icep_vectorid=229466&kwid=902099&mtid=824&kw=lg Quote Link to comment Share on other sites More sharing options...
19Echo Posted December 30, 2012 Share Posted December 30, 2012 thank you Quote Link to comment Share on other sites More sharing options...
