walter_J64bit Posted August 29, 2010 Share Posted August 29, 2010 Does anyone here have the install documents for this 7800 A/V mod? I need reinstall the one I have. Quote Link to comment Share on other sites More sharing options...
jaybird3rd Posted August 29, 2010 Share Posted August 29, 2010 The 8BitDomain site is offline, and the 7800 documentation doesn't seem to be in the Wayback Machine, so I've attached it in HTML format. It's over 2MB, so I split the ZIP file, and I had to rename the second part because the forum software didn't recognize the extension. Download both, rename "7800Install_02.zip" to "7800Install.z01", and extract "7800install.zip" into a separate folder (your ZIP utility should find and open the second part automatically; I created these with PKZIP). Then, open HTML file inside the folder. 7800Install.zip 7800Install_02.zip Quote Link to comment Share on other sites More sharing options...
walter_J64bit Posted August 29, 2010 Author Share Posted August 29, 2010 The 8BitDomain site is offline, and the 7800 documentation doesn't seem to be in the Wayback Machine, so I've attached it in HTML format. It's over 2MB, so I split the ZIP file, and I had to rename the second part because the forum software didn't recognize the extension. Download both, rename "7800Install_02.zip" to "7800Install.z01", and extract "7800install.zip" into a separate folder (your ZIP utility should find and open the second part automatically; I created these with PKZIP). Then, open HTML file inside the folder. Thanks! WinRAR didn't like the files but I get it to unzip the files! Quote Link to comment Share on other sites More sharing options...
