bohoki Posted September 13, 2010 Share Posted September 13, 2010 (edited) since my last batch went over decent i once again offer pc joysticks with adapters that have start buttons $25 each shipped in continental usa yes i'm even offering up the awesome pole position wheel controller even though its usefulness is not very good other than gorf,superbreakout,kaboom,space invaders,galaxian,buck rogers,river raid) ive also used it with moon patrol any questions? i'll be back with more description Edited September 13, 2010 by bohoki Quote Link to comment Share on other sites More sharing options...
tz101 Posted September 14, 2010 Share Posted September 14, 2010 I have the white one with the gray handle that is in the center of your photo. It does not work well with most of my games though. Quote Link to comment Share on other sites More sharing options...
atariksi Posted September 14, 2010 Share Posted September 14, 2010 I have the white one with the gray handle that is in the center of your photo. It does not work well with most of my games though. I got the Gravis joystick from him and it has the self-centering adjuster and works pretty good for many games (not including Ms. Pac-man). Quote Link to comment Share on other sites More sharing options...
bohoki Posted September 14, 2010 Author Share Posted September 14, 2010 I have the white one with the gray handle that is in the center of your photo. It does not work well with most of my games though. did you use the calibration dials to center it with missile command? Quote Link to comment Share on other sites More sharing options...
Divya16 Posted September 14, 2010 Share Posted September 14, 2010 I have the white one with the gray handle that is in the center of your photo. It does not work well with most of my games though. did you use the calibration dials to center it with missile command? That's one thing I noticed with PC joysticks, they have calibration stuff whereas Atari 5200 joysticks use no calibration but still seem to center pretty good although the buttons are low-quality. Quote Link to comment Share on other sites More sharing options...
bohoki Posted September 14, 2010 Author Share Posted September 14, 2010 I have the white one with the gray handle that is in the center of your photo. It does not work well with most of my games though. did you use the calibration dials to center it with missile command? That's one thing I noticed with PC joysticks, they have calibration stuff whereas Atari 5200 joysticks use no calibration but still seem to center pretty good although the buttons are low-quality. yea most pc joysticks are made as cheaply as can possibly work also that a 5200 stick has a range of 0-500k and center is anywhere between 200k and 300k a pc joysitck has a range of 0-100 k and center is anywhere between 45-55k its a bit more fiddley and pc computers were not a standard speed so there was lots of variables Quote Link to comment Share on other sites More sharing options...
Zoyx Posted September 15, 2010 Share Posted September 15, 2010 I bought an adapter with a PC joystick off of ebay. Fire button works, but in Missile command, everything goes to the right and sticks there. How do you calibrate? Or is it just broken? Quote Link to comment Share on other sites More sharing options...
bohoki Posted September 15, 2010 Author Share Posted September 15, 2010 I bought an adapter with a PC joystick off of ebay. Fire button works, but in Missile command, everything goes to the right and sticks there. How do you calibrate? Or is it just broken? generally when things go down and right it means the plug got unplugged a little first off make sure it is plugged in firmly and there is no strain on the cord (with missile command,superbreakout,kaboom,gorf or starwars) then leaving the joystick alone turn it on then press start while the game is playing move the joytick in a circle then let it snap back to center see where the cursor is use the adjusters on the stick to make it where you want it to be(up down isnt easy with supbreakout,gorf,kaboom) if all else fails then check the joystick on a pc gameport things do break a wire could break in the cord a wire could desolder inside the adapter wires could break with excessive flexing Quote Link to comment Share on other sites More sharing options...
Zoyx Posted September 15, 2010 Share Posted September 15, 2010 Working now. I did a dumb dyslexia thing with the calibration wheels on the joystick. Quote Link to comment Share on other sites More sharing options...
bohoki Posted September 15, 2010 Author Share Posted September 15, 2010 Working now. I did a dumb dyslexia thing with the calibration wheels on the joystick. i hear ya they put those things everywhere top, sides, bottom and sometimes its clockwise=right sometimes its reverse the one that bugs me is the lower left gravis it doesn't have calibration adjusters so it is perpetually a tad to the left and up which is only annoying in starwars and missile command Quote Link to comment Share on other sites More sharing options...
atariksi Posted September 16, 2010 Share Posted September 16, 2010 Working now. I did a dumb dyslexia thing with the calibration wheels on the joystick. i hear ya they put those things everywhere top, sides, bottom and sometimes its clockwise=right sometimes its reverse the one that bugs me is the lower left gravis it doesn't have calibration adjusters so it is perpetually a tad to the left and up which is only annoying in starwars and missile command I prefer PC joysticks with hard-to-adjust calibrators. You hate to start a game with doubts as to whether the joystick is calibrated or not. The gravis joystick with screw type adjusters within the holes that are hard to get to unless you use a screwdriver are good. Quote Link to comment Share on other sites More sharing options...
bohoki Posted September 16, 2010 Author Share Posted September 16, 2010 Working now. I did a dumb dyslexia thing with the calibration wheels on the joystick. i hear ya they put those things everywhere top, sides, bottom and sometimes its clockwise=right sometimes its reverse the one that bugs me is the lower left gravis it doesn't have calibration adjusters so it is perpetually a tad to the left and up which is only annoying in starwars and missile command I prefer PC joysticks with hard-to-adjust calibrators. You hate to start a game with doubts as to whether the joystick is calibrated or not. The gravis joystick with screw type adjusters within the holes that are hard to get to unless you use a screwdriver are good. yea i liked that one it was really dialed in but it kind of feels slightly cheap with the little foam handle Quote Link to comment Share on other sites More sharing options...
bohoki Posted September 27, 2010 Author Share Posted September 27, 2010 no one? how about $24 each delivered? Quote Link to comment Share on other sites More sharing options...
Charlie_ Posted September 27, 2010 Share Posted September 27, 2010 I threw away all my PC analog controllers a long time ago. I do have a ton of 2 button analog controllers for the TRS-80 Color Computer. (Tandy 1000 also). I'd like an adapter to use those if its possible. Quote Link to comment Share on other sites More sharing options...
bohoki Posted September 27, 2010 Author Share Posted September 27, 2010 I threw away all my PC analog controllers a long time ago. I do have a ton of 2 button analog controllers for the TRS-80 Color Computer. (Tandy 1000 also). I'd like an adapter to use those if its possible. i dont like saying anything is impossible but i think they use the pots backwards like atari paddles like right/down = 0 resistance left/up = maximum resistance and i do not have a sample to test i would not even attempt also those pots in there are really jittery anyway Quote Link to comment Share on other sites More sharing options...
