RSS Bot Posted September 25, 2010 Share Posted September 25, 2010 Woofer cutout - that's an 11" square with 3" corner radii. There's the port, 14.5" X 2" X 16.75". Sides and bottom of box is used to form the port. Finally ready to make the woofer cutouts. It's starting to look like a box now. Close-up of opening, showing the port. Note all panels sit inside dados and are completely sealed. Another front shot. Holes are drilled for the eight #10-32 T-Nuts. The T-Nuts press in easily with this heavy duty 3" c-clamp. All pressed in. This woofer will be held firmly and can be removed without damaging the box. All that's left is some minor Bondo along the edges / joints and stretching the black... http://www.atariage.com/forums/blog/341/entry-7491-cougar-stereo-install-pt3/ Link to comment Share on other sites More sharing options...
