supermanbidder Posted September 26, 2010 Share Posted September 26, 2010 i have a 4 port 5200 it is power moded not to use the av power selector it works fine ,but no color at all Quote Link to comment Share on other sites More sharing options...
Charlie_ Posted September 26, 2010 Share Posted September 26, 2010 i have a 4 port 5200 it is power moded not to use the av power selector it works fine ,but no color at all I had a 5200 a long time ago that did the same thing. I had to swap one of the chips with a new one. Here are some posts from 2002.......... http://www.atariage.com/forums/topic/11458-everything-is-black-and-white/page__p__111752__hl__black%20and%20white__fromsearch__1#entry111752 Quote Link to comment Share on other sites More sharing options...
supermanbidder Posted September 28, 2010 Author Share Posted September 28, 2010 i have a 4 port 5200 it is power moded not to use the av power selector it works fine ,but no color at all I had a 5200 a long time ago that did the same thing. I had to swap one of the chips with a new one. Here are some posts from 2002.......... http://www.atariage.com/forums/topic/11458-everything-is-black-and-white/page__p__111752__hl__black%20and%20white__fromsearch__1#entry111752 any idea what chips might be suspect ? i have a copy of the service manual and schematics thanks Quote Link to comment Share on other sites More sharing options...
Charlie_ Posted September 28, 2010 Share Posted September 28, 2010 i have a 4 port 5200 it is power moded not to use the av power selector it works fine ,but no color at all I had a 5200 a long time ago that did the same thing. I had to swap one of the chips with a new one. Here are some posts from 2002.......... http://www.atariage.com/forums/topic/11458-everything-is-black-and-white/page__p__111752__hl__black%20and%20white__fromsearch__1#entry111752 any idea what chips might be suspect ? i have a copy of the service manual and schematics thanks I'm trying to find a picture of the mother board to show you. Its not the ram bios or the pokey, I don't think. I'll keep looking. Look at this pic here: I think the chip is the largest chip on the lower right side of the board. http://i146.photobucket.com/albums/r255/delfmeek/DSCN0573.jpg Quote Link to comment Share on other sites More sharing options...
mylok Posted November 26, 2013 Share Posted November 26, 2013 I hope someone can help with this no color problem. I have a 4 port that is s-video and power modified and can not get it to display any color. It had the color problem before the mods I used this as my first 5200 mod unit. I have replaced every chip on the board from another working 5200 4 port but still no color. After swapping all of the chips one at a time and testing after each swap the board that had color working still has color output but the board with the problem still does not display color. I also had a problem with the controllers on this unit and replaced 5 of the chips close to the joystick ports and that fixed the problem with the joystick. The buttons were off press 5 and it registers and some buttons didn't work and the joystick only worked up and down. I bought replacement chips for the joystick problem on ebay 5 chips for $3.00 with free shipping (seemed like a good deal to me). I can post a picture of the chips that need to be replaced for the joystick problem if anyone needs that info. So if the chips are not bad any idea what would cause no color output? I tested the color adjustment pot as well and it works fine. Any Ideas? Thanks in advance. Quote Link to comment Share on other sites More sharing options...
