RSS Bot Posted September 27, 2010 Share Posted September 27, 2010 OK, now that the Tetris in the NES HSC began, I have been playing it like crazy ever since I got up and discovered it had been posted. I played and played, my eyes were blurred from playing, but still I kept on. I finally got a score I deemed worthy enough to post. But then I figured out that if you hold A and pressed start to start the game, you can start at the level you chose +10! So then that changed everything. I knew I could get a score higher than what I had posted with that info in mind. A few hours later, after many failed attempts, I got a cool 1/3 of the way to 999,999! What I don't understand is why when you get 100 lines if you start on level 15, you go to level 16. Shouldn't it be after you get 159 lines, you go to level 16? Also, it is hot in here. So hot I had to turn on the air conditioner. Mom won't be here until 7pm so I can do that (until she gets home and starts yelling about how cold it is when it really isn't!) She will be at my... http://www.atariage.com/forums/blog/168/entry-7496-aagh-my-body/ Link to comment Share on other sites More sharing options...
