Roydea6 Posted October 20, 2010 Share Posted October 20, 2010 SIO2PC Pigula made. Won't boot anymore. Symptoms are: Red screen No action on boot up except that the LCD screen turns red. No error codes visible. Swapped SD cards -- same symptoms -- ATARI folder is on the root / with other folders inside. Quote Link to comment Share on other sites More sharing options...
+orpheuswaking Posted October 20, 2010 Share Posted October 20, 2010 Sounds like a toasted Atmega... May need to be reprogrammed Quote Link to comment Share on other sites More sharing options...
Mathy Posted October 20, 2010 Share Posted October 20, 2010 Hello rdea6 Sounds like a toasted Atmega... May need to be reprogrammed Make sure BODEN and BODLEVEL are set. You may have fried the Atmega while hotplugging it. Setting these fuse bits will prevent this. sincerely Mathy Quote Link to comment Share on other sites More sharing options...
