CV Gus Posted November 16, 2010 Share Posted November 16, 2010 Well, it's been a while... Some time ago, I posted some info on two kinds of adapters that would let you use almost any 9-pin controller with a 5200. After considering my financial situation and other practical factors, I'm going to just build the battry-powered version. This one has the overwhelming advantage of using nearly any 9-pin controller, even a CV! It will also allow use of the paddle controller. Only one button function (a problem with Pole Position), but it is also passive at that point. I'm also thinking of a special add-on that will allow two-button function on even a one-button controller. So far, the biggest problem is with the 7800 controller buttons. But that is minor. It may also allow better use of the 5200 light gun! Quote Link to comment Share on other sites More sharing options...
