bogax Posted November 29, 2012 Share Posted November 29, 2012 (edited) Here's a version with some asm The asm routine is in a macro. putting it in a macro allows passing a data statement as a parameter to a particular instance. macro WRIPFMAC asm ldx {2} ldy {3} lda {4} clc adc {2} sta {4} WRI_LOOP lda {1},y sta $A4,x iny inx cpx {4} bcc WRI_LOOP end end To use it as a subroutine you'd give a label, invoke the macro with it's four parameters then supply a return. The four parameters (in this order) are: The name of the data statement. The variable used to pass the location of the first byte to be written in the playfield. The variable used to pass the location of the first byte in the data statement. The variable used to pass the number of bytes to move and this one gets modified. So eg you create a subroutine using the macro. Then to use it set up the three variables and call the subroutine. pf_ptr = 0 : dat_ptr = top_tbl[top] : dat_len = 12 gosub WRI_PF pf_ptr = 12 : dat_ptr = mid_tbl[mid] : dat_len = 20 gosub WRI_PF pf_ptr = 32 : dat_ptr = bot_tbl[bot] : dat_len = 12 gosub WRI_PF return otherbank WRI_PF callmacro WRIPFMAC room_dat pf_ptr dat_ptr dat_len return thisbank http://pastebin.com/W3pWSNS9 Here's a second macro. Use is the same. This has a little more overhead but is faster in the loop so you save a few cycles for moving more than 1 line. It also costs a few more bytes It uses temp variables temp1-temp4 but doesn't touch the parameter variables. macro WRIPFMAC asm lda #$00 sta temp2 ldy {4} clc lda #$A4 adc {2} sta temp1 lda {3} adc #<{1} sta temp3 lda #>{1} adc #$00 sta temp4 WRI_LOOP lda (temp3),y sta (temp1),y dey bpl WRI_LOOP end end Edited November 29, 2012 by bogax Quote Link to comment Share on other sites More sharing options...
+Gemintronic Posted November 29, 2012 Author Share Posted November 29, 2012 Thanks again, bogax. Also, for using the words "streamline" instead of "clean up his rubbish code" Speaking of which, does this still run over CPU cycles with the new inline asm bogax cooked up? Quote Link to comment Share on other sites More sharing options...
bogax Posted November 30, 2012 Share Posted November 30, 2012 Speaking of which, does this still run over CPU cycles with the new inline asm bogax cooked up? I think the short answer is yes fact is, I've forgotten what all I've done about that I said in a previous post that it was still going over even with a liberal sprinkling of drawscreens I'm not seeing that now I put a drawscreen at the beginning of the print_style routine and that seems to take care of it even with the for-next loop version. Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted December 1, 2012 Share Posted December 1, 2012 I told bogax the other day that I would try to make a version of your original program with the new data that VbB can produce, but the code seemed to hop to a million places, so I couldn't figure out how to use all the data I already converted after using Generate Items From Code. I gave up on that and decided to use the latest code that bogax posted. Here's the playable version of his code: destiny0001_with_asm.bin I took his code and stuffed in an adapted version of my smooth collision/collision prevention code to see if it would work. I'm not sure if all of the numbers have been converted correctly, but it seems to be working. I also fixed it so objects in rooms won't visually hop around or share the score color for a fraction of a second. Here's my adapted version: destiny0001_with_asm_and_smooth_collision_2012y_12m_01d_0725t.bin destiny0001_with_asm_and_smooth_collision_2012y_12m_01d_0725t.bas Move the joystick and 'rub' the little rectangle along the walls diagonally and you should see a difference. Quote Link to comment Share on other sites More sharing options...
+Gemintronic Posted December 1, 2012 Author Share Posted December 1, 2012 I truly appreciate the contributions here. Although I am still wrapping my head around bogaxs changes Also, thank you RT for looking at the visible warping of objects as they try to find a free place on-screen. Just so I understand: your fix was to set the objects color to the same one as the floor? Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted December 1, 2012 Share Posted December 1, 2012 I truly appreciate the contributions here. Although I am still wrapping my head around bogaxs changes Also, thank you RT for looking at the visible warping of objects as they try to find a free place on-screen. Just so I understand: your fix was to set the objects color to the same one as the floor? Yep, I made the object the same color as the background until it finds its final resting place, but I figured the player might still see the object if it overlaps the playfield pixels while doing its dance, so I put it behind the playfield pixels using CTRLPF = $25. I also added COLUP0 = _objectcolor under print_style so the object will never turn red. If someone with better programming skills can double check the numbers in my smooth collision/collision prevention code, then we won't have to worry if there are any hidden problems with that. I love gliding along walls instead of sticking to them. Quote Link to comment Share on other sites More sharing options...
+Gemintronic Posted December 1, 2012 Author Share Posted December 1, 2012 bogax pointed out a flaw that was still causing CPU cycle overruns. Basically, my bit shifting code is taking up too much time. Unfortunately this is also the crux of level creation for Destiny. It relies on the value gameseed to control which rooms appear where. Without sufficient bit shuffling the distribution is pretty weak - meaning the level layout has recognizable, repeatable patterns. My only solution is to add additional drawscreens during bit shuffling. I dunno is any of the assembly wizards have a better pseudo random number generator that can be cut-and-pasted in? Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted December 1, 2012 Share Posted December 1, 2012 I tried it over and over again, but so far the program hasn't stopped in Stella using autoexec.stella. Quote Link to comment Share on other sites More sharing options...
bogax Posted December 3, 2012 Share Posted December 3, 2012 (edited) I tried it over and over again, but so far the program hasn't stopped in Stella using autoexec.stella. I expect that's because I added a drawscreen at the beginning of print_style routine. I rewrote the randomization stuff to speed it up but it's not enough. edit: looks like adding inlinerand might do it calc_roomtype if dungeonlvl{1} then temp2 = %00100100 : temp3 = %00000010 else temp2 = 0 : temp3 = 0 if worldx{0} then temp1 = %01001001 : temp2 = temp2 | %00000001 else temp1 = 0 if worldy{6} then temp1 = temp1 | %00000010 if worldy{0} then temp1 = temp1 | %00010000 if dungeonlvl{0} then temp1 = temp1 | %00100100 if worldy{2} then temp1 = temp1 | %10000000 temp1 = temp1 * 2 + temp1 if worldy{4} then temp2 = temp2 | %00000010 if temp1{7} then temp2 = temp2 | %00001000 if worldy{1} then temp2 = temp2 | %00010000 if worldx{1} then temp2 = temp2 | %01000000 : temp3 = temp3 | %00000001 if temp1{1} then temp2 = temp2 | %10000000 if dungeonlvl{5} then temp3 = temp3 | %00000100 if worldx{2} then temp3 = temp3 | %00001000 if worldy{2} then temp3 = temp3 | %00010000 if dungeonlvl{2} then temp3 = temp3 | %00100000 if temp1{3} then temp3 = temp3 | %01000000 if worldy{7} then temp3 = temp3 | %10000000 temp1 = temp1 * 2 + temp2 + temp3 + gameseed if temp1 then rand = temp1 else rand = 255 roomtype = rand tempvar = rand + worldx + worldy if counter > 230 then roomtype = rand if worldx = 128 && worldy = 128 && dungeonlvl = 1 then roomtype = 1 rclass = roomtype / 4 / 4 : roomtype = roomtype & $0F if rclass = 15 then rclass = style_a return thisbank Edited December 3, 2012 by bogax Quote Link to comment Share on other sites More sharing options...
SmasherImp Posted December 6, 2012 Share Posted December 6, 2012 I've gotta say, I really like this idea! A multi floor, randomly generated dungeon crawler where you collect treasure and bank it back at floor 1 sounds awesome to me. One thing you could do to keep count of both the rings and your floor, is to add 1000 to your score every time you go up (and subtract each time you go down), and add 1 for every ring you collect. This way it simulates 2 3-digit 'scores'. Just an idea anyway. Keep it up Quote Link to comment Share on other sites More sharing options...
+Gemintronic Posted December 6, 2012 Author Share Posted December 6, 2012 I've gotta say, I really like this idea! A multi floor, randomly generated dungeon crawler where you collect treasure and bank it back at floor 1 sounds awesome to me. One thing you could do to keep count of both the rings and your floor, is to add 1000 to your score every time you go up (and subtract each time you go down), and add 1 for every ring you collect. This way it simulates 2 3-digit 'scores'. Just an idea anyway. Keep it up Thanks for the words of encouragement. I was kinda thinking of using the score either for an inventory display or.. ..have the score be the combination time limit / hit points ala Gauntlet or E.T. Does that make sense? Quote Link to comment Share on other sites More sharing options...
jrok Posted December 6, 2012 Share Posted December 6, 2012 I was kinda thinking of using the score either for an inventory display or.. ..have the score be the combination time limit / hit points ala Gauntlet or E.T. Why not both? http://www.atariage.com/forums/topic/93867-using-the-score-for-a-game-title-or-inventory-strip/#entry1139891 Quote Link to comment Share on other sites More sharing options...
+Gemintronic Posted December 6, 2012 Author Share Posted December 6, 2012 Why not both? http://www.atariage....p/#entry1139891 That's actually pretty cool. I don't know how I missed that. I'll make sure to study the examples. I'm actually more hot and bothered about using the new bit-array reading techniques from bogax to make multi-screen levels. I don't know where I'm going wrong. Here's my attempt to print out the top left hand screen from a 2x2 screen DATA array. It prints out very strange. The main idea is to treat a DATA statement like a 2 dimensional binary array so you could do things like map(x,y) and get 1 for solid or 0 for space. bitplayfield3.zip Quote Link to comment Share on other sites More sharing options...
+Gemintronic Posted December 6, 2012 Author Share Posted December 6, 2012 Just for comparison THIS bit of code works fine for DATA statements that are *just* big enough for one screen. I'd like a bit array much larger than one screen that I can scroll through. set romsize 4k dim mapx = a dim mapy = b dim cell = c dim cellx = d COLUPF=$FF COLUBK=$00 mapx = 0 mapy = 0 printcol for mapy = 0 to 10 : gosub printrow : next goto main printrow for mapx = 0 to 31 : gosub printpf : next return printpf cellx = mapx & 7 cell = mapy + mapy * 3 + mapx / 8 if map[cell] & setbits[cellx] then pfpixel mapx mapy on else pfpixel mapx mapy off return main drawscreen goto main rem use an adressable set of masks so you can point rem to them with a variable data setbits %10000000, %01000000, %00100000, %00010000 %00001000, %00000100, %00000010, %00000001 end data clearbits %01111111, %10111111, %11011111, %11101111 %11110111, %11111011, %11111101, %11111110 end data map %11111111, %11111111, %11111111, %11111111 %10000000, %00000000, %00000000, %00000001 %10100000, %00000000, %00111111, %11111001 %10100000, %00100000, %00100000, %00110001 %10100000, %00100000, %00100000, %11000001 %10100000, %00101111, %11100011, %00000001 %10100000, %00111000, %00001100, %00000001 %10100000, %00000000, %00110000, %00000001 %10111111, %11111111, %11000000, %00000001 %10000000, %00000000, %00000000, %00000001 %11111111, %11111111, %11111111, %11111111 end Quote Link to comment Share on other sites More sharing options...
jrok Posted December 6, 2012 Share Posted December 6, 2012 (edited) I'm actually more hot and bothered about using the new bit-array reading techniques from bogax to make multi-screen levels. I don't know where I'm going wrong. Here's my attempt to print out the top left hand screen from a 2x2 screen DATA array. It prints out very strange. The main idea is to treat a DATA statement like a 2 dimensional binary array so you could do things like map(x,y) and get 1 for solid or 0 for space. It looks like you might have a slight data visualization problem here. I could be wrong since I don't know what you think it should look like, but from the way you have your data table laid out, it seems like you have 64 bits per rows instead of 32 bits per row (you are only going to be accessing 32 bits per row, per screen). So, while you are expecting to see a bitmap of the first "half" of each row, what the program is actually printing is this: data map %11111111, %11111111, %11111111, %11111111, %11111111, %11111111, %11111111, %11111111 %10000000, %00000000, %00000000, %00000001, %10000000, %00000000, %00000000, %00000001 %10100000, %00000000, %00111111, %11111001, %10100000, %00000000, %00111111, %11111001 %10100000, %00100000, %00100000, %00110001, %10100000, %00100000, %00100000, %00110001 %10100000, %00100000, %00100000, %11000001, %10100000, %00100000, %00100000, %11000001 %10100000, %00101111, %11100011, %00000001, %10100000, %00100001, %11100011, %00000001 %10100000, %00111000, %00001100, %00000001, %10100000, %00000000, %00001100, %00000001 %10100000, %00000000, %00110000, %00000001, %10100000, %00000000, %00110000, %00000001 %10111111, %11111111, %11000000, %00000001, %10111111, %11000001, %11000000, %00000001 %10000000, %00000000, %00000000, %00000001, %10000000, %00000000, %00000000, %00000001 %11111111, %11111111, %11111111, %11111111, %11111111, %11111111, %11111111, %11111111 %10101010, %01010101, %01010101, %01010100, %01010101, %01010001, %01010101, %01010101 %10000000, %00000000, %00000000, %00000001, %00000000, %00000000, %00000000, %00000001 %10000000, %00000000, %00000001, %10000001, %00100000, %00000000, %00111111, %11111001 %10000000, %00100000, %00000000, %00110001, %00100000, %00100000, %00100000, %00110001 %10000000, %00100000, %00000000, %11000001, %00100000, %00100000, %00100000, %11000001 %10000000, %00101111, %10000011, %00000001, %00100000, %00100111, %11100011, %00000001 %10000000, %00111000, %00000000, %00000001, %00100000, %00111000, %00001100, %00000001 %10000000, %00000000, %00000000, %00000001, %00100000, %00000000, %00110000, %00000001 %10000000, %11111111, %00000000, %00000001, %10000011, %10000011, %11000000, %00000001 %10000000, %00000000, %00000000, %00000001, %10000000, %00000000, %00000000, %00000001 %11111111, %11111111, %11111111, %11111111, %11111111, %11111111, %11111111, %11111111 end That's what you'll see if you insert a hard return at the midway point in each row of your table. You'll see that the output of your program matches exactly the first ten rows of the bitmap image you are feeding it, but maybe not the way you were expecting it. Look at my attached version (I re-mapped the table to read "JROK WAS HERE") and see if it makes sense to you. The way you laid out your table, it looks to me like you thought it was reading bytes 0-3, then bytes 8-11, then bytes 16-19, etc. You could still potentially lay it out your way, just add a table pointer that accounts for the 4-byte shift when it picks which row to print. I also saved you 34 bytes by wrapping your bitmapper into a single for-loop. Cheers, J bitplayfield4.bas.bin bitplayfield4.bas Edited December 6, 2012 by jrok Quote Link to comment Share on other sites More sharing options...
bogax Posted December 6, 2012 Share Posted December 6, 2012 (edited) First off if you're going to do things that are in whole bytes it'll be much faster to handle things in whole bytes So for example assuming the line in the data statement that goes to a line in the playfield starts at the beginning of a byte and ends at the end of a byte (ie it does NOT start half way through a byte, say at bit 4, and ending half way through a byte at bit 4) then it will be much faster to just transfer the 4 bytes than call pfpixel 32 times. pfpixel "knows" about rows and columns but the data statement doesn't. You've got 8 bytes per line in the data statement. the first row starts at 0 0-7 bytes inclusive for the first line in the data statement. The second line of the data statement begins with byte 8 of the data statement, bytes 8-15 inclusive etc 4 bytes per line of the playfield (columns 0-31 inclusive) so the playfield lines correspond to data statement bytes like so (for the upper left corner of the data statement) pfrow pfbytes data statement bytes 0 0-3 0-3 1 4-7 8-11 2 8-11 16-19 You could do something like in this post: http://www.atariage....50#entry2641780 and build a counter in for-next loops that counts by bits bytes and rows in the data statement except instead of taking an early out at 28 bits you'd take your early out at four bytes You wouldn't need a special test you'd just need a for-next loop that counted the correct four bytes. (an early out being 'quit this data statement row and go to the next data statement row') And of course it'll have to maintain a pfpixel columns, rows counter in parallel pfcolumns advance on every bit and get reset to 0 after every four bytes. pfrows advance every four bytes. edit: you elaborated while I was composing you could still do something similar except maybe count through the data statement by bits and rows taking your early out after 32 bits which would be, I suppose, when you've finished one playfield row data statement rows would still go by 8 bytes data statement bits would have to pick out the correct 32 bits, which would be the same for each row you'd start at some bit and row in the data statement count through data statement bit and pfcolumns in parallel and when you've done 32 bits of the playfield column go to the next data statement row reseting every thing to where ever it needs to be for the next row (pfcolumn to 0, data statement bit to the starting bit in the row, pfrow to the next pfrow) or you could still count through the data statement by bits, bytes, and rows which I think would be faster but probably not faster enough to make it worth the added complication. . Edited December 6, 2012 by bogax Quote Link to comment Share on other sites More sharing options...
bogax Posted December 6, 2012 Share Posted December 6, 2012 (edited) Here's an UNTESTED routine that counts through pf columns and rows maintaing a ds_byte counter and a current_bit counter in parallel You supply it with the first column and row from the data statement in ds_col and ds_row there's 64 columns 0-63 in the data statement but you only want to go up to 32 or you'll get into the next data statement row when writing the playfield obviously, rows will be similar and if you go too far you'll fall off the end of the data statement http://pastebin.com/JyGxd3dv dim pf_row = a dim pf_col = b dim ds_start_bit = c dim current_bit = d dim current_byte = e dim ds_byte = e dim ds_col = g dim ds_row = h printpf ds_byte = ds_col / 8 ds_byte = ds_row * 8 + ds_byte ds_start_bit = ds_col & 7 for pf_row = 0 to 10 current_bit = setbits[ds_start_bit] current_byte = map[ds_byte] for pf_col = 0 to 31 if current_byte & current_bit then pfpixel pf_col pf_row on else pfpixel pf_col pf_row off current_bit = current_bit / 2 rem if current_bit = 0 then done with one rem data statement byte so go to the next rem get the corresponding map byte rem and reset current_bit to the first bit column if current_bit = 0 then ds_byte = ds_byte + 1 : current_byte = map[ds_byte] : current_bit = $80 next rem we have incremented ds_byte by 4 rem in the pf_col loop rem 8 bytes per data statement row rem we need to advance 4 more to go to the rem next row in the data statement ds_byte = ds_byte + 4 next return data setbits %10000000, %01000000, %00100000, %00010000 %00001000, %00000100, %00000010, %00000001 end data map %11111111, %11111111, %11111111, %11111111, %11111111, %11111111, %11111111, %11111111 %10000000, %00000000, %00000000, %00000001, %10000000, %00000000, %00000000, %00000001 %10100000, %00000000, %00111111, %11111001, %10100000, %00000000, %00111111, %11111001 %10100000, %00100000, %00100000, %00110001, %10100000, %00100000, %00100000, %00110001 %10100000, %00100000, %00100000, %11000001, %10100000, %00100000, %00100000, %11000001 %10100000, %00101111, %11100011, %00000001, %10100000, %00100001, %11100011, %00000001 %10100000, %00111000, %00001100, %00000001, %10100000, %00000000, %00001100, %00000001 %10100000, %00000000, %00110000, %00000001, %10100000, %00000000, %00110000, %00000001 %10111111, %11111111, %11000000, %00000001, %10111111, %11000001, %11000000, %00000001 %10000000, %00000000, %00000000, %00000001, %10000000, %00000000, %00000000, %00000001 %11111111, %11111111, %11111111, %11111111, %11111111, %11111111, %11111111, %11111111 %10101010, %01010101, %01010101, %01010100, %01010101, %01010001, %01010101, %01010101 %10000000, %00000000, %00000000, %00000001, %00000000, %00000000, %00000000, %00000001 %10000000, %00000000, %00000001, %10000001, %00100000, %00000000, %00111111, %11111001 %10000000, %00100000, %00000000, %00110001, %00100000, %00100000, %00100000, %00110001 %10000000, %00100000, %00000000, %11000001, %00100000, %00100000, %00100000, %11000001 %10000000, %00101111, %10000011, %00000001, %00100000, %00100111, %11100011, %00000001 %10000000, %00111000, %00000000, %00000001, %00100000, %00111000, %00001100, %00000001 %10000000, %00000000, %00000000, %00000001, %00100000, %00000000, %00110000, %00000001 %10000000, %11111111, %00000000, %00000001, %10000011, %10000011, %11000000, %00000001 %10000000, %00000000, %00000000, %00000001, %10000000, %00000000, %00000000, %00000001 %11111111, %11111111, %11111111, %11111111, %11111111, %11111111, %11111111, %11111111 end Edited December 7, 2012 by bogax Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted December 7, 2012 Share Posted December 7, 2012 That's actually pretty cool. I don't know how I missed that. I'll make sure to study the examples. I actually posted in that thread, then forgot about it. Be sure to look at the post farther down in that thread: http://www.atariage.com/forums/topic/93867-using-the-score-for-a-game-title-or-inventory-strip/#entry1620834 Quote Link to comment Share on other sites More sharing options...
+Gemintronic Posted February 21, 2013 Author Share Posted February 21, 2013 Not sure how I'm gonna proceed with this one. I can't use "Destiny" as the title as Bungie is making some big MMO with that name. The real nuggets of gold in my source are: * The code that use a single variable to place an object type in a 256x256x256 screen world. * The dungeon layout generator. It's somewhat akin to a polynomial counter. For any given x/y value it'll always generate the same room. I could take this game in any number of directions including: * More Zelda like. Even hearts as if 6lives.asm still works. * More Elder Scrolls/Nethack style with forests, cities, deserts, etc.. * More Treasures of Tarmin like. Full 3D maze. Quote Link to comment Share on other sites More sharing options...
Cybearg Posted February 21, 2013 Share Posted February 21, 2013 Why can't you call it Destiny? Even if there is another game with the name, you're not basing this game off of it and Bungee doesn't have a copyright on that word. I'd be super-impressed if you could do convincing pseudo-3D environments for the 2600 without doing it all in Assembly. Quote Link to comment Share on other sites More sharing options...
+Gemintronic Posted February 21, 2013 Author Share Posted February 21, 2013 Why can't you call it Destiny? Even if there is another game with the name, you're not basing this game off of it and Bungee doesn't have a copyright on that word. I'd be super-impressed if you could do convincing pseudo-3D environments for the 2600 without doing it all in Assembly. 3D view is not an issue. Lawyers are the issue. Remember Mojang and "Scrolls"? Even though I was first with "Destiny" Bungie has paid Lawyers. It's not if you can win a case - it's if you can afford it. Quote Link to comment Share on other sites More sharing options...
Cybearg Posted February 22, 2013 Share Posted February 22, 2013 I'm super-impressed. Quote Link to comment Share on other sites More sharing options...
+Gemintronic Posted February 22, 2013 Author Share Posted February 22, 2013 I'm super-impressed. What did you (or anyone else) think of the three possible directions I could take this? A. More Zelda. This would mean more open floor areas. Focus on one or two useable items at a time. Maybe overworld and underworld areas. B. More Nethack/Oblivion. Focus on creating an open world. Towns, dungeons, forests etc.. incorporating more old school RPG elements. C. More Treasure of Tarmin. Changing the perspective to 3D. More lean towards Treasure of Tarmin rules. I was thinking of maybe showing your character move through the 3D maze instead of a hard and fast 3d perspective. You would watch your character move through the maze instead of pixel by pixel movement control. Quote Link to comment Share on other sites More sharing options...
Cybearg Posted February 22, 2013 Share Posted February 22, 2013 I don't see why you couldn't do a combination. A 3D-based Zelda/Roguelike along the lines of Legend of Grimrock. Personally, I'm not big on "open world" even on systems that can make it interesting. On something like the 2600, I don't see how it wouldn't be a lot of empty nothing that you just have to plod through, since graphics and space are so extremely limited. In my opinion, keep interaction tight and gameplay dense. 3D is partly just for the gimmick of it being a rare thing to see, but it also serves the purpose of helping to guarantee that encounters require fewer sprites, as you probably won't have multiple enemies on screen at a time when you're limited to a pseudo-3D space like that. Make it about finding awesome items and dealing with random monster generation to get deeper and deeper. ... But that's my perspective as a big fan of The Binding of Isaac. 1 Quote Link to comment Share on other sites More sharing options...
