ninoy1995 Posted November 24, 2010 Share Posted November 24, 2010 For the Atari 2600 Jr., when you open up the console, what you see underneath the "Select" and "Reset" switches is a thin plastic with circuit traces. I beleive they call this the mylar switch. My question is. What causes that "burn" or the black spot on the circuit trace on the mylar switch on old Atari 2600 Jr.? Appreciate your inputs. Thanks! Quote Link to comment Share on other sites More sharing options...
+5-11under Posted November 24, 2010 Share Posted November 24, 2010 I've never looked at this on a 2600 Jr. specifically, but I'm guessing it's corrosion (or burning from high current, although I find that hard to believe). Either way, some gentle scrubbing with a pink eraser should help. Quote Link to comment Share on other sites More sharing options...
A.J. Franzman Posted November 25, 2010 Share Posted November 25, 2010 (edited) Probably simple tarnish. Silver is a main ingredient of printed conductor "inks" in membrane switches because of its high conductivity, plus the interesting property that unlike other metals' oxides, silver oxide is nearly as conductive as pure silver. There's no need to clean it off; doing so only adds a high risk of damaging the part. If it works, don't mess with it. If the switches work sometimes but are unreliable, you might try modifying them as I described here. Edited November 25, 2010 by A.J. Franzman Quote Link to comment Share on other sites More sharing options...
+5-11under Posted November 25, 2010 Share Posted November 25, 2010 Sounds good. I guess if it ain't broke, don't fix it. Quote Link to comment Share on other sites More sharing options...
zylon Posted November 27, 2010 Share Posted November 27, 2010 When it's broken is usually the best time. Quote Link to comment Share on other sites More sharing options...
ninoy1995 Posted November 29, 2010 Author Share Posted November 29, 2010 Thank you all for your inputs! Cheers! Quote Link to comment Share on other sites More sharing options...
