daafies Posted November 24, 2010 Share Posted November 24, 2010 why is everyone hating on the switch box of the 4 port 5200? sure its RF, but *shrugs*, it works fine, no? Quote Link to comment Share on other sites More sharing options...
BigO Posted November 24, 2010 Share Posted November 24, 2010 Except when it doesn't. I have a dozen or so doesn'ts around here somewhere. It's an obstacle to keeping the old hardware running. The 2 port model didn't have it. I can see why somebody thought it was a good idea. Quote Link to comment Share on other sites More sharing options...
OldAtarian Posted November 25, 2010 Share Posted November 25, 2010 (edited) It's meant to reduce cable clutter but got a bad rap by some people claiming it starts fires, which has never, ever been proven. Mostly, though, it's one of the more expensive parts to replace if yours stops working or you buy a system that doesn't come with one. I've seen a few lately as low as $20 but $30-$40 is more the norm. That's a lot of money compared to the $5 switchbox the 2600 uses. Edited November 25, 2010 by OldAtarian Quote Link to comment Share on other sites More sharing options...
Divya16 Posted November 25, 2010 Share Posted November 25, 2010 It's meant to reduce cable clutter but got a bad rap by some people claiming it starts fires, which has never, ever been proven. Mostly, though, it's one of the more expensive parts to replace if yours stops working or you buy a system that doesn't come with one. I've seen a few lately as low as $20 but $30-$40 is more the norm. That's a lot of money compared to the $5 switchbox the 2600 uses. I have seen sparks but only when you plug in the RF cable into it while switchbox is plugged in. If you leave your system plugged in, you don't see any sparks. Quote Link to comment Share on other sites More sharing options...
WERY Posted November 26, 2010 Share Posted November 26, 2010 why is everyone hating on the switch box of the 4 port 5200? sure its RF, but *shrugs*, it works fine, no? It is easy to hate something that aint good. I do however collect the model that used the switchbox cause I want the good BIOS and 4-ports insted of just 2. I was'nt so hard to modify the 5200 so I will do it over and over again Quote Link to comment Share on other sites More sharing options...
daafies Posted November 26, 2010 Author Share Posted November 26, 2010 thanks for all the replies. i guess i am lucky that my switchbox has been behaving. great topic. keep the atari alive! david Quote Link to comment Share on other sites More sharing options...
Charlie_ Posted November 30, 2010 Share Posted November 30, 2010 thanks for all the replies. i guess i am lucky that my switchbox has been behaving. great topic. keep the atari alive! david Its not bad. A working switch box is just fine. I do like the single wire to the console. Problem is over the years the switch box might get separated from the console and making the console useless unless it or a replacement is found. The sparking thing is bullshit. You have to plug the power supply to the wall after the RF wire is hooked up. Even so... It sparks at 1st contact. I've seen just as big of a spark plugging the 9V adapter into the back of a 2600. Quote Link to comment Share on other sites More sharing options...
OldAtarian Posted November 30, 2010 Share Posted November 30, 2010 why is everyone hating on the switch box of the 4 port 5200? sure its RF, but *shrugs*, it works fine, no? It is easy to hate something that aint good. I do however collect the model that used the switchbox cause I want the good BIOS and 4-ports insted of just 2. I was'nt so hard to modify the 5200 so I will do it over and over again And just why, exactly, "ain't" it good? Keep in mind you'll get thumped if you say it's dangerous. Quote Link to comment Share on other sites More sharing options...
