RSS Bot Posted December 3, 2010 Share Posted December 3, 2010 Now that I've socketed the CPU and other custom ICs, I can fit the adapter I've constructed. The idea of this is to bring out all the CPU signals to a convenient header in order to avoid the frequent need to solder jumpers to legs of the CPU: I wanted to use pins on the header, but since the daughterboard which will plug into the top of the adapter is also single-sided veroboard, it's easier to use sockets. The jumpers attached to the adapter are for the 1MB SIMM upgrade. It's already a lot neater than it used to be... Once everything is working, I'll construct an ARC Clock which will plug into the adapter, requiring only two jumper leads to the IOR/W lines on the IntSDX board. http://www.atariage.com/forums/blog/281/entry-7674-socketing-the-atari-xe-continued/ Link to comment Share on other sites More sharing options...
