Chuplayer Posted January 7, 2011 Share Posted January 7, 2011 Like, a controller diagnostic cart or a game that has functions mapped to every spot on the keypad so you can test the keypad quickly? Even a diagnostic ROM that you can put on an Atarimax USB cart would do the trick. Quote Link to comment Share on other sites More sharing options...
+Allan Posted January 7, 2011 Share Posted January 7, 2011 Like, a controller diagnostic cart or a game that has functions mapped to every spot on the keypad so you can test the keypad quickly? Even a diagnostic ROM that you can put on an Atarimax USB cart would do the trick. Yes, it's called Pete's Test cart. Look at the 5200 game section here at Atariage. Allan Quote Link to comment Share on other sites More sharing options...
bohoki Posted January 8, 2011 Share Posted January 8, 2011 Like, a controller diagnostic cart or a game that has functions mapped to every spot on the keypad so you can test the keypad quickly? Even a diagnostic ROM that you can put on an Atarimax USB cart would do the trick. Yes, it's called Pete's Test cart. Look at the 5200 game section here at Atariage. Allan i test with 3 games missle command to check the stick for jitters then i test the keypad with galaxian as pressing each button skips to the corresponding level and digdug gives you the feel for the up down left right and both buttons Quote Link to comment Share on other sites More sharing options...
Chuplayer Posted January 8, 2011 Author Share Posted January 8, 2011 Like, a controller diagnostic cart or a game that has functions mapped to every spot on the keypad so you can test the keypad quickly? Even a diagnostic ROM that you can put on an Atarimax USB cart would do the trick. Yes, it's called Pete's Test cart. Look at the 5200 game section here at Atariage. Allan Freakin' sweet! Thanks! I'll have to check it out. Is it available in the AtariAge store? It's down at the moment. Worst case scenario, I can put it on an AtariMax USB cart. Like, a controller diagnostic cart or a game that has functions mapped to every spot on the keypad so you can test the keypad quickly? Even a diagnostic ROM that you can put on an Atarimax USB cart would do the trick. Yes, it's called Pete's Test cart. Look at the 5200 game section here at Atariage. Allan i test with 3 games missle command to check the stick for jitters then i test the keypad with galaxian as pressing each button skips to the corresponding level and digdug gives you the feel for the up down left right and both buttons This also will work. Thank you! Quote Link to comment Share on other sites More sharing options...
Chuplayer Posted January 8, 2011 Author Share Posted January 8, 2011 Just wanted to say thanks again. I found a lot on ebay that is supposed to come with a 4-port console, two rebuilt controllers, and all three of those games. I don't plan on getting an AtariMax right now, but Pete's Test Cart will have its day in the sun Quote Link to comment Share on other sites More sharing options...
