RSS Bot Posted February 28, 2011 Share Posted February 28, 2011 The Titlescreen Kernel is a custom assembly module that allows you to display a high quality titlescreen in your batari Basic game, without having to write any assembly code yourself. This will walk you through creating the most basic titlescreen. If you want to learn more about how this works, or creating a titlescreen by hand, please read the documentation included with the titlescreen Kernel download. The following steps will walk you through building a basic titlescreen using the included samples: 1. Install the Titlescreen Kernel – Download, unzip, and copy the titlescreen folder to the same folder as visualbB.exe. It should contain the following: 2. Download this test version of VisualbB Build 558 VisualbB_1.0_Build_558.zip (849.55K) Number of downloads: 0 3. Make sure you have the VisualbB Sound library... http://www.atariage.com/forums/blog/302/entry-7911-using-the-title-screen-kernel-wizard/ Link to comment Share on other sites More sharing options...
