FABombjoy Posted December 16, 2002 Share Posted December 16, 2002 Hello all, Recently I rescued an Atari 400 from someone's quite dingy basement. After a good cleaning, I powered up the ole' machine and was playing Defender. Being new to Atari 8-bit computers, I was pleasantly suprised to be playing the game that I knew and loved from the 5200, only with a joystick that wasn't pissing me off. So, I turn it off, change carts, and turn it on.... only, no dice. No power LED, nothing. Checked continuity on power & lid switches and they're A-OK. Take the meter to the power supply, 9.5-6 volts. Decided to test it under load, plugged it in to the 400 and it dropped to about 4-5V. The only other equipment that I own that uses AC is my Odyssey2, and it refused to work with the Atari supply, making me think that it is probably the PS. I'd try the O2 PS in the Atari, but the Atari supply is rated for a decent amount of current more. Long story short... Should I check anything else before I try to locate a new power supply? Is there any comperable power supply that isn't Atari NOS? I'd really rather use something more modern... But I don't know what uses AC power supplies anymore. As a sidenote, I had a 5200 PS go out on me between cart changes before. I'm cursed, I tell you. Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted December 16, 2002 Share Posted December 16, 2002 Lick the end to be sure. j/k Actually, if you are getting any power at all...couldn't you just try to light up a LED that costs less than a buck? If it doesn't light, there's your answer (though the cord leading into the power supply might have a broken wire or something). As a drastic measure, you could try chopping up the cord and wiring a new one. Quote Link to comment Share on other sites More sharing options...
jjessop Posted December 16, 2002 Share Posted December 16, 2002 Take the top off and measure +12 vdc and +5 vdc off of the regulators bolted to the black anodized heat sink. I'm betting both will be way low and you probably have a bad diode in the bridge rectifier circuit. The console power LED operates off of the -5 vdc BTW. The RAM in an 800/400 use -5 vdc, hence the need for an AC input supply as it was easier to get a negative voltage that way Quote Link to comment Share on other sites More sharing options...
FABombjoy Posted December 16, 2002 Author Share Posted December 16, 2002 After my post, I remembered that the NES uses AC, so I tried the 400 PS in that. Didn't work. I briefly tapped the NES PS on the 400 power connector, and the power LED came to life. I'm pretty sure is the Atari PS now. Quote Link to comment Share on other sites More sharing options...
somePUNK Posted December 16, 2002 Share Posted December 16, 2002 i'm pritty sure my nes dsoen't work with my 400 power supply so i wouldn't count on that Quote Link to comment Share on other sites More sharing options...
tyranthraxus Posted December 18, 2002 Share Posted December 18, 2002 I don't own a 400 but I had a similar problem with an 800 which might be the same problem. On the 800 you have to flip a lid to get at the cartridge bay. The computer would not turn on with this lid in the up position! I don't know if the bay lid has a switch connected to it but perhaps you did the same thing? John Quote Link to comment Share on other sites More sharing options...
