0078265317 Posted May 3, 2011 Share Posted May 3, 2011 Have a bad controller. Need a new mylar to replace the bad one in my controller. Besides ebay where can I get one. Best and every one sells the whole kit. I just need the mylar not the whole kit. Doesn't have to be gold. Unless it is easy to fix my current one like someone said put lines on top or something. Not sure how that would work. Quote Link to comment Share on other sites More sharing options...
tz101 Posted May 3, 2011 Share Posted May 3, 2011 By "mylar" you are referring to the flex circuit. Best is the best place to buy them separate (no repair kit purchase required), and I paid about $5 a piece for them about a month ago, so not badly priced either. FYI. Quote Link to comment Share on other sites More sharing options...
0078265317 Posted May 3, 2011 Author Share Posted May 3, 2011 I only saw the whole kit there. I never saw just the flex circuit listed. Quote Link to comment Share on other sites More sharing options...
zylon Posted May 3, 2011 Share Posted May 3, 2011 It's better to call Best and talk to someone rather than searching that website. It can be confusing. Quote Link to comment Share on other sites More sharing options...
Charlie_ Posted May 3, 2011 Share Posted May 3, 2011 I have purchased and used many flex circuits from ebay sellers , all rev9 and all work very well. Quote Link to comment Share on other sites More sharing options...
0078265317 Posted May 3, 2011 Author Share Posted May 3, 2011 I have a revision 9 and works great also but one in a while the buttons don't work unless I press hard. Or remove the controller and put it back in the 5200. So every mylar wears out eventually I guess. Anyhow best should redesign the site or hire someone. Quote Link to comment Share on other sites More sharing options...
zylon Posted May 3, 2011 Share Posted May 3, 2011 I have a revision 9 and works great also but one in a while the buttons don't work unless I press hard. Or remove the controller and put it back in the 5200. So every mylar wears out eventually I guess. Anyhow best should redesign the site or hire someone. Hmmm. That's interesting. I bought 2 new Rev 9's last year and they both have to be pressed hard until used awhile. My best controller is using an original Rev 7 and no upgrades, yet it works perfectly every time. All I did was clean it and reinstall. Quote Link to comment Share on other sites More sharing options...
0078265317 Posted May 3, 2011 Author Share Posted May 3, 2011 (edited) I have two 9 controllers and 1 7 controller. One 9 would not work. Took it apart and tapped the kepad mylar button area with a screw driver and it started working. Reassembled everything and all is good. All buttons. The other 9 works great no issues. Then today started acting up. Took it apart and noticed the start pause and reset had gold round foil buttons on it. Wanted to see what revision it was. So that is why I took it apart. It was also a 9. So I have 2 9s now. Anyhow after putting it back together (* , 7 , 4 , 1) no longer work. Not sure why. And the 7 works great except the start pause and reset. And fire buttons never worked either. So took it apart and took out the mylar and saw sticky stuff on the fire buttons. Tried to scrape it off but couldn't. Got frustrated and gave up. Put it all back together. Now fire buttons work. Not sure how they started working. But at least super breakout works now and so does Galaxian.au Pole position never works not sure why even if I squeese really hard on the fire buttons on any controller but jungle hunt does great. And also(* , 7 , 4 , 1) no longer work on the 7. Not sure what happened. And I have 1 wico with custom y cable baught from bohoki (twothousandman) on ebay. Edited May 3, 2011 by 0078265317 Quote Link to comment Share on other sites More sharing options...
zylon Posted May 3, 2011 Share Posted May 3, 2011 Sounds like either a trace on the "mylar" got cracked or a wire not making good connection for a whole line of keys to be out. Quote Link to comment Share on other sites More sharing options...
0078265317 Posted May 3, 2011 Author Share Posted May 3, 2011 I took the 9 apart again and refused to work. No matter where I pressed. Then it magically started working not sure what happened. All keys. Then I put it back together and the keys (* , 7 , 4 , 1) stopped working again. Weird. Quote Link to comment Share on other sites More sharing options...
0078265317 Posted May 3, 2011 Author Share Posted May 3, 2011 Well I took apart the 9 again and reseted everything. Now all buttons work so got lucky. Until it starts acting up again. But for now all good. Now to fiddle with the 7 again. Quote Link to comment Share on other sites More sharing options...
0078265317 Posted May 3, 2011 Author Share Posted May 3, 2011 The 7 is hopeless. I'm just going to get new mylat for that. Took it apart. Cut out a piece of tin foil the size of the pad and put under neath and same for start pause and reset. Now all works but only for galaxian. All buttons except # doesn't switch between 1 and 2 player and does nothing in jungle hunt where it normally switches between beginner normal and advanced. And start pause and reset work now but only in galaxian and no other game. Weird. So I'll just get a new mylar. Quote Link to comment Share on other sites More sharing options...
Charlie_ Posted May 3, 2011 Share Posted May 3, 2011 Get all new rev9 flex circuits and make sure all the buttons have metal contacts. Its easy to use a hole punch aluminum foil and some super glue. Use a tweezer to place the metal dots, be patient and let the super glue dry good before trying to install the buttons / key pads back in the controller. Ive experienced a lot of 5200 controllers with bad wires. They seemed to work until you shook the wire. Also sometimes where the flex circuit goes into the wire harness is a trouble spot. Quote Link to comment Share on other sites More sharing options...
0078265317 Posted May 3, 2011 Author Share Posted May 3, 2011 Well both 9s work now. As for the 7 I will eventually replace it. Quote Link to comment Share on other sites More sharing options...
ClausB Posted May 10, 2011 Share Posted May 10, 2011 On mine (don't remember the rev #) several key columns did not work. I traced the faults to the gray vertical stripes which look like flat paint on the flex circuit. I have read that some folks have repainted them with conductive paint (like auto rear window defogger repair paint) but I just taped a strand of wire on top of each stripe and they all work now. Quote Link to comment Share on other sites More sharing options...
0078265317 Posted May 10, 2011 Author Share Posted May 10, 2011 What kind of wire? Quote Link to comment Share on other sites More sharing options...
ClausB Posted May 11, 2011 Share Posted May 11, 2011 A bare strand of copper wire, thin and flexible enough to conform to the surface of the stripe. A narrow strip of tape keeps it in place (don't tape over the key contacts) and the assembled keypad grid presses it down to maintain contact. Quote Link to comment Share on other sites More sharing options...
