abaudrand Posted May 5, 2011 Share Posted May 5, 2011 I'm trying to make a cable to connect my 7800 to a betaSP recorder which has a 12-PIN component Input. As I guess the plug of the 7800 is impossible to find as stand alone, I want to add a female SCART -> 12 PIN component cable at the end of the 7800 cable. does someone know what signal goes out of the SCART of the 7800 so that I can solder it correctly to the component cable? Quote Link to comment Share on other sites More sharing options...
CPUWIZ Posted May 5, 2011 Share Posted May 5, 2011 Last time I checked, there is no SCART connector on the 7800. Unless you have a mad-mod that I don't know about. Quote Link to comment Share on other sites More sharing options...
abaudrand Posted May 6, 2011 Author Share Posted May 6, 2011 uh... I mean it got a kind of SCART to be plugged to TV but the signal seems to be RGB as I can't have something when I use a common VCR to watch it. Quote Link to comment Share on other sites More sharing options...
GroovyBee Posted May 6, 2011 Share Posted May 6, 2011 Last time I checked, there is no SCART connector on the 7800. Unless you have a mad-mod that I don't know about. Unless you have a French SECAM/Peritel 7800 . It has an additional video circuit. Quote Link to comment Share on other sites More sharing options...
abaudrand Posted May 6, 2011 Author Share Posted May 6, 2011 Last time I checked, there is no SCART connector on the 7800. Unless you have a mad-mod that I don't know about. Unless you have a French SECAM/Peritel 7800 . It has an additional video circuit. Yes I though the problem could come from that despite the burst signal is the same in PAL or SECAM. So I've plug it into an VCR which recognize both PAL/SECAM standard but the screen still black. I got an old BETASP which got a component plug so I though that I could easily solder a cable but the 7800 blueprint doesn't show the output assignement. Quote Link to comment Share on other sites More sharing options...
dwane413 Posted May 6, 2011 Share Posted May 6, 2011 I'm not sure if I understand your problem, but maybe this will help. The output from a normal unmodified Atari is not composite and as far as I know, there aren't any Atari's that have been modded for component. If you want more info about that, see this post. You can't plug an Atari into composite or component and expect it to work. You need a Coaxial (F-Type) to Female RCA Adapter or something similar. Then you connect it to the TV antenna input and use channel 2 or 3. If that doesn't work, I've read that some Atari's use UHF. I don't know much about that, but here is a starting point it you want to read about it. Quote Link to comment Share on other sites More sharing options...
abaudrand Posted May 6, 2011 Author Share Posted May 6, 2011 I'm not sure if I understand your problem, but maybe this will help. The output from a normal unmodified Atari is not composite and as far as I know, there aren't any Atari's that have been modded for component. If you want more info about that, see this post. You can't plug an Atari into composite or component and expect it to work. You need a Coaxial (F-Type) to Female RCA Adapter or something similar. Then you connect it to the TV antenna input and use channel 2 or 3. If that doesn't work, I've read that some Atari's use UHF. I don't know much about that, but here is a starting point it you want to read about it. thanks for the threads. I knew its not composite but I though it could be a kind of RGB component output similar to the Amiga as you could directly plug an amiga in TV but not a VCR. When reading the 7800 blueprint, there are separate channel for R,G and B (upper right part of the blueprint as far as I remembered) so I hope I can make it... hmm... seems not so easy now. Quote Link to comment Share on other sites More sharing options...
+Mitch Posted May 6, 2011 Share Posted May 6, 2011 The PAL SCART 7800 is outputting RGB from the SCART port. I have heard some people say they were able to get composite out of it as well but I've never been able to replicate that. I suspect your VCR is looking for composite. Mitch Quote Link to comment Share on other sites More sharing options...
dwane413 Posted May 6, 2011 Share Posted May 6, 2011 I goofed with my post above. For some unknown reason I was thinking about the Atari 2600. I don't know as much about the 7800. Anyway, part of what I said may have been incorrect in regards to the 7800. Sorry. Quote Link to comment Share on other sites More sharing options...
