Ataritard Posted May 13, 2011 Share Posted May 13, 2011 I have two of these TI-99/4a systems so I've narrowed the problem down to the video modulator box. I get the video but no sound. Is this common? Any ideas? Quote Link to comment Share on other sites More sharing options...
Astharot Posted May 13, 2011 Share Posted May 13, 2011 Hello, if you are american and have usa version of ti99 you can built a easy video cable. Connector Din in usa Ti99 (NTSC mode) have 5 pin, just use pin 4 for video and pin 3 for sound. Also if you are European and have TI99 Pal Mode, video out have 6 pin and the cable is a little bit difficult.. the wires no 2 but 4. One for audio and 3 for video in mode video composite Using a tester for found a pin where is 12V and start a numeration pin. Look -> http://pinouts.ru/connectors/din5dm.gif Pin Name Description 1 12V +Vid (NO USE IT!!!) 2 R-Y red video output 3 AUDIO Sound output 4 Y green (or video composite out in usa version) 5 B-Y blue video output 6 GND GROUND Good Work !!! 1 Quote Link to comment Share on other sites More sharing options...
Ataritard Posted May 14, 2011 Author Share Posted May 14, 2011 Hello, if you are american and have usa version of ti99 you can built a easy video cable. Connector Din in usa Ti99 (NTSC mode) have 5 pin, just use pin 4 for video and pin 3 for sound. Also if you are European and have TI99 Pal Mode, video out have 6 pin and the cable is a little bit difficult.. the wires no 2 but 4. One for audio and 3 for video in mode video composite Using a tester for found a pin where is 12V and start a numeration pin. Look -> http://pinouts.ru/connectors/din5dm.gif Pin Name Description 1 12V +Vid (NO USE IT!!!) 2 R-Y red video output 3 AUDIO Sound output 4 Y green (or video composite out in usa version) 5 B-Y blue video output 6 GND GROUND Good Work !!! Thank you. I will do this. Quote Link to comment Share on other sites More sharing options...
zylon Posted May 14, 2011 Share Posted May 14, 2011 I made one of those using the cable from a dead RF modulator. It gives a better picture than when it was new. Quote Link to comment Share on other sites More sharing options...
Ataritard Posted June 26, 2011 Author Share Posted June 26, 2011 I figured out what was wrong with my AV cable... Quote Link to comment Share on other sites More sharing options...
