acertain Posted May 29, 2011 Share Posted May 29, 2011 I purchased the Longhorn board via http://electronicsentimentalities.com/. The instructions there (http://electronicsentimentalities.com/2600InstallationInstructions.html) say to remove a capacitor and resistor on the 2600 main board. The instructions on the Longhorn site (http://www.longhornengineer.com/Videomods/L6switchNTSC) make no mention of that. I noticed that the instructions on the LH site show a 2.2E rev board and I have 2.2G. Is that the difference? Should I remove those components or not? Thanks. Andrew Quote Link to comment Share on other sites More sharing options...
acertain Posted May 31, 2011 Author Share Posted May 31, 2011 In case other people find this posting searching for the same answer, I didn't remove the components and everything works great for composite video. I haven't tried S-video. Also, I wasn't sure how heavy gauge wire I needed and ended up using Cat-5e wire, and that seems to be working fine as well (I have +5v and GND wired with 18-gauge, but that was too heavy for everything else and I didn't have anything between 18-gauge and the cat-5). I was worried that it would be too light-weight, but it seems to work fine. Andrew Quote Link to comment Share on other sites More sharing options...
flammingcowz Posted May 31, 2011 Share Posted May 31, 2011 From what I have heard, removing those stops it from recombining the video and sending it to the RF output when it doesn't need to. This should clean up the video a little also. Quote Link to comment Share on other sites More sharing options...
zylon Posted June 1, 2011 Share Posted June 1, 2011 What I did was remove the modulator instead of the components. I needed it for my Video Pinball unit. Quote Link to comment Share on other sites More sharing options...
