Drakon Posted June 5, 2011 Share Posted June 5, 2011 (edited) There's many advantages to the AV famicom. The AV famicom is the only known model of the nes that doesn't have video interference when you modify it to use a rgb ppu chip. Also the av famicom is a top loader meaning that games will always work on it. The av famicom has controller ports for standard nes controllers and it's small and looks nice. Here's what I did to my av famicom: Here's how the system looks when everything's been put back together: As you can see, this av famicom has been modified almost as much as humanly possible. Here's the features of it: This av famicom outputs true rgb, s-video, and composite video from the multi av port at the back. This multi av port is the same video port as you find on a snes, my system is wired the same way as the snes so all you need to do is buy snes rgb/s-video/composite video cables to get the video signals out to your tv. Here's some comparison screenshots between the s-video on my av famicom vs the composite video from a standard non-modified nes: That takes care of the eye candy. My av famicom also features a very nice custom audio circuit. This audio circuit increases the bass, and it also does a better job mixing in all the audio than the default circuit on the famicom/nes. This audio circuit also does psuedo stereo sound seperation. And this audio circuit fully supports famicom games that use advanced audio chips. Here's a youtube video I made showing the difference in audio before/after I applied the audio mod: http://www.youtube.com/watch?v=RLGo_P-MNG4&feature=player_embedded The last mod I did to the av famicom system itself was I swapped out a chip with another chip that makes the system compatible with the nintendo powerpak compact flash cartridge. Here's screenshots showing that happens to the video before and after you replace the chip: And since the powerpak outputs extended audio found in certain games and the famicom disk system I modified my nes to famicom adapter to mix that advanced audio into the system audio circuit: If you're looking for any more information regarding my work it's easiest to contact me through my small forum here: My link I hope you people enjoy my work Edited June 5, 2011 by Drakon 2 Quote Link to comment Share on other sites More sharing options...
OldSchoolRetroGamer Posted June 5, 2011 Share Posted June 5, 2011 Wow very impressive! Quote Link to comment Share on other sites More sharing options...
PsychoKittyNet Posted June 6, 2011 Share Posted June 6, 2011 Eh, the picture quality doesent seem that much better than composite to me, esspescially considering the cost and effort of the set up. Quote Link to comment Share on other sites More sharing options...
OldSchoolRetroGamer Posted June 6, 2011 Share Posted June 6, 2011 Eh, the picture quality doesent seem that much better than composite to me, esspescially considering the cost and effort of the set up. To each his own but there is clearly a significant difference, well worth the effort and satisfying I am sure with every game he loads. Quote Link to comment Share on other sites More sharing options...
keilbaca Posted June 6, 2011 Share Posted June 6, 2011 I had a chance to get ahold of an AV Famicom when I was in japan... but I was too broke at the time. The place didn't have anymore when I went again... so mad I passed that up. That's an amazing set of mods, and everything looks super clean. Do you have a tutorial on everything that you did? Quote Link to comment Share on other sites More sharing options...
thgill Posted June 7, 2011 Share Posted June 7, 2011 Excellent looking mod with clearly superior video results. Quote Link to comment Share on other sites More sharing options...
Drakon Posted June 7, 2011 Author Share Posted June 7, 2011 I had a chance to get ahold of an AV Famicom when I was in japan... but I was too broke at the time. The place didn't have anymore when I went again... so mad I passed that up. That's an amazing set of mods, and everything looks super clean. Do you have a tutorial on everything that you did? I'm not going to make a tutorial for a couple of reasons. This mod is done by building a kit I ordered from japan. The instructions for the kit are all in japanese. And the other reason is that this mod is nowhere near beginner level. Here's where I bought my kit from: My link good luck Quote Link to comment Share on other sites More sharing options...
ApolloBoy Posted June 9, 2011 Share Posted June 9, 2011 The last mod I did to the av famicom system itself was I swapped out a chip with another chip that makes the system compatible with the nintendo powerpak compact flash cartridge. What chip is this? I plan on RGB modding my Twin Famicom and I use my Powerpak a lot, so having this info would be great. Quote Link to comment Share on other sites More sharing options...
Drakon Posted June 9, 2011 Author Share Posted June 9, 2011 (edited) The last mod I did to the av famicom system itself was I swapped out a chip with another chip that makes the system compatible with the nintendo powerpak compact flash cartridge. What chip is this? I plan on RGB modding my Twin Famicom and I use my Powerpak a lot, so having this info would be great. you need to replace the "HD74LS373P" with a "TC74HC373P" The chip that you need to replace it with is usually labelled as just "74HC373AP" Edited June 9, 2011 by Drakon Quote Link to comment Share on other sites More sharing options...
DarthCloud Posted June 9, 2011 Share Posted June 9, 2011 Funny I managed to order this kit too 2 week ago, waiting to receive it!. Currently I'm using NJM2267 videos amp for the RGB mod of my AV Famicom. I'm using this with my XRGB3 to output it on my TV via VGA. But I'm see some small "jailbar" effet on my TV. Are you using an XRGB3 too, or you wired directly to your monitor? Do you see any "jailbar" with this??? Thank you, can wait to receive the part and mod mine too!! Quote Link to comment Share on other sites More sharing options...
NightSprinter Posted June 9, 2011 Share Posted June 9, 2011 From what I remember, these systems modified with a PC-10 or Titler's PPU chip do not have full compatibility (some games, like even the crappy Dragon's Lair" wouldn't work at all due to lack of color emphasis bits). Quote Link to comment Share on other sites More sharing options...
Drakon Posted June 9, 2011 Author Share Posted June 9, 2011 Funny I managed to order this kit too 2 week ago, waiting to receive it!. Currently I'm using NJM2267 videos amp for the RGB mod of my AV Famicom. I'm using this with my XRGB3 to output it on my TV via VGA. But I'm see some small "jailbar" effet on my TV. Are you using an XRGB3 too, or you wired directly to your monitor? Do you see any "jailbar" with this??? Thank you, can wait to receive the part and mod mine too!! Oh hi cloud nice to see you again. I have this system plugged straight into my crt tv using the s-video that the kit internally generates. I hope you ordered the version of the kit with the parts for the audio circuit because it sounds really amazing. I have very very very faint jailbars on the powerpak where I have to be right next to the tv to even notice them. The jailbars on this system are still 10x better than the jailbars from my rgb nes. I built the njm amp a long time ago I still have it somewhere. Also before I ordered this kit I had the background flickering anytime I had a game with a solid blue background (like the bosses in mario 2 us) which was super annoying. This kit fixes that problem. I also discovered from this kit that when I was using the njm amp having the rgb signals travel over a rgb cable and then get converted to s-video the longer the cable was the more blurry the picture became. So if you're like me and you just want s-video then using this kit is a lot better because it gives you a much sharper picture. From what I remember, these systems modified with a PC-10 or Titler's PPU chip do not have full compatibility (some games, like even the crappy Dragon's Lair" wouldn't work at all due to lack of color emphasis bits). Yes that's right a handful of really crappy games no longer work. Big deal. Quote Link to comment Share on other sites More sharing options...
NightSprinter Posted June 9, 2011 Share Posted June 9, 2011 It's not just crappy games, that was a big thing about the console stuff. Even some of the good European titles won't work, because quite a few of 'em relied heavily on the color emphasis bits. Quote Link to comment Share on other sites More sharing options...
horseboy Posted June 9, 2011 Share Posted June 9, 2011 It's not just crappy games, that was a big thing about the console stuff. Even some of the good European titles won't work, because quite a few of 'em relied heavily on the color emphasis bits. Is there a list somewhere? Quote Link to comment Share on other sites More sharing options...
Drakon Posted June 9, 2011 Author Share Posted June 9, 2011 (edited) It's not just crappy games, that was a big thing about the console stuff. Even some of the good European titles won't work, because quite a few of 'em relied heavily on the color emphasis bits. Is there a list somewhere? here's the only list I ever found. I havn't tried any of these games myself. So far every game I've tried has worked perfectly. "Paperboy 1/2 Just Breed Magician Totally Rad Airwolf Fantastic Adventures of Dizzy Super Spy Hunter Immortal " and here's a picture of totally rad working with a rgb ppu: so maybe even this list is wrong. Edited June 9, 2011 by Drakon Quote Link to comment Share on other sites More sharing options...
NightSprinter Posted June 10, 2011 Share Posted June 10, 2011 Asterix also has rendering issues on RGB (gray background instead of black as a start). Quote Link to comment Share on other sites More sharing options...
Drakon Posted June 10, 2011 Author Share Posted June 10, 2011 Asterix also has rendering issues on RGB (gray background instead of black as a start). just because something has a one different colour doesn't mean that the game is ruined and therefore becomes unplayable. Quote Link to comment Share on other sites More sharing options...
NightSprinter Posted June 10, 2011 Share Posted June 10, 2011 I never said it was ruined, just pointing out another game that's affected in some way due to the RC2C05-99 and RP2C03B's lack of color emphasis bits. Quote Link to comment Share on other sites More sharing options...
Drakon Posted June 10, 2011 Author Share Posted June 10, 2011 I never said it was ruined, just pointing out another game that's affected in some way due to the RC2C05-99 and RP2C03B's lack of color emphasis bits. I mean I think every game on the rgb system will have one or two colours that're either slightly off or different. Still everything works great Quote Link to comment Share on other sites More sharing options...
NightSprinter Posted June 11, 2011 Share Posted June 11, 2011 Oh I agree, even Chris Covell on his "I Want My RGB" site stated that certain games on the NES actually had better colors on composite. But again, it's up to the user to decide which they prefer. 1 Quote Link to comment Share on other sites More sharing options...
Drakon Posted June 11, 2011 Author Share Posted June 11, 2011 (edited) Oh I agree, even Chris Covell on his "I Want My RGB" site stated that certain games on the NES actually had better colors on composite. But again, it's up to the user to decide which they prefer. Well here's a little tip for you. The colours on the rgb system are WAY more vibrant. The colours are a lot stronger. In fact everytime I play a composite system everything looks dull and washed out. Having everything so bright and colourful makes me not care when one colour is a little off now and then. Also having everything being crystal clear helps too. Edited June 11, 2011 by Drakon Quote Link to comment Share on other sites More sharing options...
NightSprinter Posted June 11, 2011 Share Posted June 11, 2011 I'm just going to say this and drop it: no need to lecture me on anything. I already know what you've said. I'm done on this thread. Quote Link to comment Share on other sites More sharing options...
Drakon Posted June 11, 2011 Author Share Posted June 11, 2011 (edited) I'm just going to say this and drop it: no need to lecture me on anything. I already know what you've said. I'm done on this thread. My point is the positive effects of these mods far outweight the negative effects. So if you like it then fine, please post elsewhere. Edited June 11, 2011 by Drakon Quote Link to comment Share on other sites More sharing options...
Drakon Posted June 19, 2011 Author Share Posted June 19, 2011 I made a video comparing the video and audio quality difference between the a regular nes and one of my upgraded av famicoms. When I uploaded the vid to youtube the quality wasn't that great so here's the link to download the video from megaupload: http://www.megaupload.com/?d=IBWBZCBX Quote Link to comment Share on other sites More sharing options...
Drakon Posted July 1, 2011 Author Share Posted July 1, 2011 http://www.youtube.com/watch?v=tIJ2gRC77qA&feature=channel_video_title Quote Link to comment Share on other sites More sharing options...
