abaudrand Posted June 6, 2011 Share Posted June 6, 2011 (edited) Hi, I recently used a SONY TRINITRON KV-14M1B TV and I had no troubles using my atari 7800 with it despite the picture is not very colorful. I've just purchased an old Amstrad 6128+ with RGB output and each time I plug it the picture is fine for about 2 seconds then it become bright grayish. I mean the black still black but all other graphics become bright. I've spent some time finding manuals on internet but not exactly the same model. On the manuals they use a symbol for the RGB input that look like this: _________ -> / . . . / /_________/ On my model , it look like this I couldn't find a chart of symbol but is it a RGB input with a strange Gamma curb? Anyone heard about this? Edited June 6, 2011 by abaudrand Quote Link to comment Share on other sites More sharing options...
GroovyBee Posted June 6, 2011 Share Posted June 6, 2011 That's a SCART socket in the bottom picture. Are you using a Peritel system or an S-Video modded system? Quote Link to comment Share on other sites More sharing options...
abaudrand Posted June 6, 2011 Author Share Posted June 6, 2011 I'm using a SCART cable for the 7800 and for the Amstrad. Normally these ones output RVB signal compatible with some CRT display. I've changed the TV to another brand and I don't have any issue but the display is blurry compare to a trinitron tube. this becoming annoying if you want to program on an amstrad, not for playing game. Quote Link to comment Share on other sites More sharing options...
GroovyBee Posted June 6, 2011 Share Posted June 6, 2011 For the 7800 what is on the other end of the cable? Is it S-video modded or a Peritel 7800? Quote Link to comment Share on other sites More sharing options...
abaudrand Posted June 6, 2011 Author Share Posted June 6, 2011 Original Peritel 7800 cable but the 7800 isn't the issue at all, I guess its the Sony trinitron which doesn't have a normal RGB input. Quote Link to comment Share on other sites More sharing options...
roland p Posted June 6, 2011 Share Posted June 6, 2011 (edited) From my memories, maybe it has to do something with pin 16. The signal on this pin will let the tv select between composite and rgb: http://en.wikipedia.org/wiki/SCART Does your scart cable has this pin connected? Edited June 6, 2011 by roland p Quote Link to comment Share on other sites More sharing options...
abaudrand Posted June 7, 2011 Author Share Posted June 7, 2011 From my memories, maybe it has to do something with pin 16. The signal on this pin will let the tv select between composite and rgb: http://en.wikipedia.org/wiki/SCART Does your scart cable has this pin connected? Thanks Roland, thats a good idea to check if the Amstrad deliver the right tension here. I'll ask my bro to bring his voltmeter friday to check the Pin 16. I've also found a way to enter into service mode but I also need a sony remote to do so. Here is the link I've found that might interest other people who have a sony TV set: http://myweb.accessus.net/~090/sonypal.html (link for NTSC also available) Quote Link to comment Share on other sites More sharing options...
abaudrand Posted June 12, 2011 Author Share Posted June 12, 2011 Ok We checked the output in Pin 16 and there is no signal at all. Thanks Roland P. So I we're gonna try to add a 1.5V battery to the wire and hope it will make the TV switch. Quote Link to comment Share on other sites More sharing options...
