sepvideo Posted June 15, 2011 Share Posted June 15, 2011 I have a 4 port 5200 that powers on but the power switch wont stay on i have to stick a item in the button to keep it on any thoughts. Quote Link to comment Share on other sites More sharing options...
zylon Posted June 15, 2011 Share Posted June 15, 2011 That sounds like a switchbox issue. The 5200 uses a momentary switch for power. Quote Link to comment Share on other sites More sharing options...
phuzzed Posted June 17, 2011 Share Posted June 17, 2011 Interesting.... I have seen a few consoles where the 5200 switch sticks. The switch can be disassembled, if necessary. I've seen the 4013 chip (U29) cause the system to either stick in an always ON or always OFF position, making it where the switch won't turn the system on or off. Like Zylon, I'm wondering if this is a switchbox issue.... Quote Link to comment Share on other sites More sharing options...
eightbitter Posted June 17, 2011 Share Posted June 17, 2011 (edited) Many years ago I accidentally plugged the power supply from 1050 to the 5200th. I did not notice the error, and dug the whole 5200 board, replaced 4013 and resistors, until I noticed that the power supply does not proper. 5200 lived happily Edited June 17, 2011 by eightbitter Quote Link to comment Share on other sites More sharing options...
Ataritard Posted June 17, 2011 Share Posted June 17, 2011 I've seen the 4013 chip (U29) cause the system to either stick in an always ON or always OFF position, making it where the switch won't turn the system on or off. I have one that is stuck ON, but I don't mind since the 5200 is the only system that you don't have to turn off and on to switch games. I'm just glad it's stuck ON instead of OFF Quote Link to comment Share on other sites More sharing options...
0078265317 Posted June 17, 2011 Share Posted June 17, 2011 I've seen the 4013 chip (U29) cause the system to either stick in an always ON or always OFF position, making it where the switch won't turn the system on or off. I have one that is stuck ON, but I don't mind since the 5200 is the only system that you don't have to turn off and on to switch games. I'm just glad it's stuck ON instead of OFF But taking a game out while the 5200 is on will damage the system won't it? Quote Link to comment Share on other sites More sharing options...
Charlie_ Posted June 17, 2011 Share Posted June 17, 2011 I've seen the 4013 chip (U29) cause the system to either stick in an always ON or always OFF position, making it where the switch won't turn the system on or off. I have one that is stuck ON, but I don't mind since the 5200 is the only system that you don't have to turn off and on to switch games. I'm just glad it's stuck ON instead of OFF But taking a game out while the 5200 is on will damage the system won't it? Taken from the 5200 FAQ here: http://www.atarihq.com/5200/5200faq/5200faq.txt * Cartridge The cartridges can be up to 32K. There are two interlock connectors that are wired together on a cartridge board. The 5200 uses this as a switch for the cartridge's power connections and as a Reset signal. Therefore, a cartridge may be safely removed or inserted while the 5200 is powered on. Quote Link to comment Share on other sites More sharing options...
0078265317 Posted June 17, 2011 Share Posted June 17, 2011 I've seen the 4013 chip (U29) cause the system to either stick in an always ON or always OFF position, making it where the switch won't turn the system on or off. I have one that is stuck ON, but I don't mind since the 5200 is the only system that you don't have to turn off and on to switch games. I'm just glad it's stuck ON instead of OFF But taking a game out while the 5200 is on will damage the system won't it? Taken from the 5200 FAQ here: http://www.atarihq.com/5200/5200faq/5200faq.txt * Cartridge The cartridges can be up to 32K. There are two interlock connectors that are wired together on a cartridge board. The 5200 uses this as a switch for the cartridge's power connections and as a Reset signal. Therefore, a cartridge may be safely removed or inserted while the 5200 is powered on. Interesting, never knew that. Thanks. Quote Link to comment Share on other sites More sharing options...
