ktalley Posted July 5, 2011 Share Posted July 5, 2011 I have a 4 port 5200 that was working fine a couple of months ago. I reconnected it recently and am unable to start almost every game. Exceptions are games that don't require the start button like mario bros or tennis. I have 5 controllers and all 5 will not allow me to start the game (including the roller ball). The controllers were working fine a couple months ago, so I don't suspect they all went defective at the same time. The other 2 buttons pause and reset work once the game has started. I tried the other 3 ports and can't start a game from those either. Is there something that is defective with my port 1 with the start button? Has anyone heard of this problem before, and if so how to correct it (hopefully without having to purchase a replacement console). Quote Link to comment Share on other sites More sharing options...
bohoki Posted July 5, 2011 Share Posted July 5, 2011 so much can go wrong its hard to pin it down #1 check your top row for missing pins verify that you machine reads the start signal by shorting pin 4 and pin 7 which is the 4th from the left and second from the right on the top row(be very careful use a little piece of wire(stay away from the bottom row cause there is 5 volts on the center bottom pin) #2 check your cable for loose connections broken wires check your controllers conductablility by putting a meter on pins 4 and 7 of the cable you could just do like i did for years and pop off the top bezel and remove the buttons and just hit the start button area of the flex circuit with the edge of a penny till o got off my ass and make a controller that freakin works from scratch Quote Link to comment Share on other sites More sharing options...
