jrok Posted July 20, 2011 Share Posted July 20, 2011 Would it be possible in the batari DPC+ kernel to mask-wrap the multiplexed P1 sprite similar to Demo 4 of the Harmony DPC+ programming thread? Demo 4 - Data Writer Demo * Unlike the DPC cartridge, the DPC+ Display Data ends up in RAM and can be modified at run time. * Joystick to move snowman - notice when he moves on/off screen he is masked to smoothly enter/exit the display. (compare with Demo 0) * Fire to flip snowman - this shows the difference between DFxWRITE and DFxPUSH. * Attached Image: DPC+ demo.bin_4.png Thanks, J Quote Link to comment Share on other sites More sharing options...
ScumSoft Posted July 20, 2011 Share Posted July 20, 2011 (edited) The demo manually masks the sprite data based on sprite location, so I don't think bB can do this right now without loading prefab'd masked sprites. I would also love to dynamically alter sprite data such as X = player sprite data index: player0[X] = $FF But I don't think anything like this is implemented right now. Edited July 20, 2011 by ScumSoft Quote Link to comment Share on other sites More sharing options...
jrok Posted July 20, 2011 Author Share Posted July 20, 2011 (edited) The demo manually masks the sprite data based on sprite location... Hmmm. So do you mean that it manually loads and repositions shapes at positions 0 and 160 to simulate a smooth exit/entry? It just surprises me a little, since I assumed that its inclusion in the demo was demonstrating a dynamic mask of some sort. In other words, since we could do this manually sans the chip, why is it part of the demo? What's the advantage being shown? Edited July 20, 2011 by jrok Quote Link to comment Share on other sites More sharing options...
ScumSoft Posted July 20, 2011 Share Posted July 20, 2011 (edited) I'll post the meaningful parts, but essentially what's being done is the data-fetchers are manually altering the bank 6 graphic data. ;---------------------------------------- ; Bank 4 - Data Writer Demo ;---------------------------------------- ; - this demo writes sprite data into the 4K Display Data Bank ; - the sprite data is masked to cause the sprite to smoothly ; go on/off screen. Normally the Atari sprites would wrap ; around and show on both sides of the display ; - use joystick to move sprite around screen ; - hit FIRE to use DFxPUSH instead of DFxWRITE to udate ; the Display Data. This causes the sprite to be upside down. ; - use LEFT DIFFICULT to control how fast the sprite moves ;---------------------------------------- ; Mask Values for smooth on-off scrolling, ; 153 = 1 pixel off the right edge ; 154 = 2 ; 155 = 3 ; 156 = 4 ; 157 = 5 ; 158 = 6 ; 159 = 7 ; 160 = 8 pixels off the right edge ; ; 255 = 1 pixel off the left edge ; 254 = 2 ; 253 = 3 ; 252 = 4 ; 251 = 5 ; 250 = 6 ; 249 = 7 ; 248 - change to 160 MaskDataR: .byte zzXXXXXXX_ .byte zzXXXXXX__ .byte zzXXXXX___ .byte zzXXXX____ .byte zzXXX_____ .byte zzXX______ .byte zzX_______ .byte zz________ MaskDataL: .byte zz_XXXXXXX .byte zz__XXXXXX .byte zz___XXXXX .byte zz____XXXX .byte zz_____XXX .byte zz______XX .byte zz_______X .byte zz________ SetMask4: lda #$FF sta OnOffMask lda FrostyX cmp #153 ; 152 bcc CopyFrostyData4 cmp #161 bcc OffRightEdge4 OffLeftEdge4: ; Frosty's off the left edge so mask him eor #$ff ; converts -1 thru -8 to +0 thru +7 tay ldx FrostyDirection bne FacingRight4 FacingLeft4: lda MaskDataL,y sta OnOffMask jmp CopyFrostyData4 OffRightEdge4: ; Frosty's off the right edge, so mask him sec sbc #153 tay ldx FrostyDirection bne FacingLeft4 FacingRight4: lda MaskDataR,y sta OnOffMask ; copy Frosty data, masking for smooth on/off if required and flipping ; image if firebutton was down CopyFrostyData4: ; read graphics from 0 lda #<FrostyGraphic0 sta DF0LOW lda #>FrostyGraphic0 sta DF0HI ; read colors from 2 lda #<FrostyColors sta DF2LOW lda #>FrostyColors sta DF2HI lda FireDown bne PrepPush4 PrepPush4: ; Fire button held down so we're prepping for PUSH ; push graphics via 1 lda #<(FrostyWrite + FrostyGraphic0Height) sta DF1LOW lda #>(FrostyWrite + FrostyGraphic0Height) sta DF1HI ; push colors via 3 lda #<(ColorWrite + FrostyGraphic0Height) sta DF3LOW lda #>(ColorWrite + FrostyGraphic0Height) sta DF3HI Write4: ldx #FrostyGraphic0Height WriteLoop4: lda DF0DATA and OnOffMask pha lda DF2DATA ldy FireDown bne PushData4 sta DF3WRITE ; fire button not down so using WRITE pla sta DF1WRITE jmp EndOfLoop4 PushData4: sta DF3PUSH ; fire button down so using PUSH pla sta DF1PUSH EndOfLoop4: dex bne WriteLoop4 So what is happening is the pointers are pointed to where frosty resides in Bank6 ram, and then updated as needed, then rewritten from a non-altered frosty when he needs to be shown again. This can be done if we could access bank6 in ASM from bB, though I haven't tried doing such a thing yet. Edited July 22, 2011 by ScumSoft Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted July 20, 2011 Share Posted July 20, 2011 (edited) It just surprises me a little, since I assumed that its inclusion in the demo was demonstrating a dynamic mask of some sort. In other words, since we could do this manually sans the chip, why is it part of the demo? What's the advantage being shown? You're posting this in the bB forms - are you overlooking that my DPC+ demo was not a demo for bB? The name for that part of the demo is Data Writer Demo. As such, it's whole purpose is to show how to write data into the DD(Display Data) bank at run time. The masking was just a way to visually show that the data changed, along with being a potential reason as to why you'd want to manipulate the DD in the first place. I have some updated masking routines, run by the ARM chip, in Chun Li that handle all 3 sizes of the player. So what is happening is the pointers are pointed to where frosty resides in Bank6 ram, and then updated as needed, then rewritten from a non-altered frosty when he needs to be shown again. This can be done if we could access bank6 in ASM from bB, though I haven't tried doing such a thing yet. Using the Copy Data to Fetcher feature, and the fact that "bank 6" for it is the original DD ROM, you could do this: 1) Copy the original, unmasked sprite image from DD ROM to DD RAM 2) point 2 DataFetchers at the sprite in DD RAM 3) Do a loop that reads using one of those DataFetchers, masks the value it read, and finally writes the masked value back out using the other DataFetcher. Edited July 20, 2011 by SpiceWare Quote Link to comment Share on other sites More sharing options...
jrok Posted July 20, 2011 Author Share Posted July 20, 2011 You're posting this in the bB forms - are you overlooking that my DPC+ demo was not a demo for bB? Um... no. That's why I specified the "Batari DPC+" kernel in the topic title. I was just wondering if a similar runtime write could be done to mask sprites in that kernel. Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted July 20, 2011 Share Posted July 20, 2011 Your text in #3 asked "why is it part of the demo?" - that's what I was responding to. Quote Link to comment Share on other sites More sharing options...
jrok Posted July 20, 2011 Author Share Posted July 20, 2011 (edited) Your text in #3 asked "why is it part of the demo?" - that's what I was responding to. I suppose I was wondering what the difference was between masking a sprite stored in RAM (as I've done before with sprites stored in Sara RAM) and the technique being shown in the demo. Although I gess I wasn't really 'wondering' that aloud, so fair enough. It wasn't meant as an offense or anything. I was asking Scumsoft to elaborate on his reply a little, so I could understand the difference. Moreover, I posted this in the bB section, and explained I was trying to understand whether the technique could be appropriated for batari's kernel, and did everything except write "Please don't come over here and yell at me, Darrell!" But, alas... Edited July 20, 2011 by jrok Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted July 20, 2011 Share Posted July 20, 2011 I'm not yelling - just was explaining the why Batari has access to Chun Li's source, and he's free to add the masking routines to bB. It's possible he's waiting for Chun Li to be officially released as the routines could be revised before then, or possibly the routines won't work as they need to know the NUSIZ for the sprite(I don't know if the bB multi-sprite DPC+ kernel supports setting that per multiplexed sprite or not). Quote Link to comment Share on other sites More sharing options...
+batari Posted July 20, 2011 Share Posted July 20, 2011 The sprite data for P1 is copied every frame, so it should be possible to optionally mask the data every frame as well. It looks like NUSIZ bits 6-7 are unused so maybe these could enable the feature - D6 could enable/disable masking, and D7 would mask on the left or right edge of the screen. I'm not sure how feasible it is to handle single, double, and quad-width sprites as the code could get a little convoluted. Quote Link to comment Share on other sites More sharing options...
ScumSoft Posted July 20, 2011 Share Posted July 20, 2011 (edited) Using the Copy Data to Fetcher feature, and the fact that "bank 6" for it is the original DD ROM, you could do this: 1) Copy the original, unmasked sprite image from DD ROM to DD RAM 2) point 2 DataFetchers at the sprite in DD RAM 3) Do a loop that reads using one of those DataFetchers, masks the value it read, and finally writes the masked value back out using the other DataFetcher. Good idea, this calls for some tests! I'll see if I can get something similar working. [edit] I've tried a few things, but during compile it names the player0 objects as player(randomID)_0 so I lose my pointer references. Otherwise this would update the player0 objects as needed: Mask_P0 rem MASK PLAYER0 if player0x <= 17 then goto maskL if player0x >= 153 then goto maskR return maskL asm lda #<(pointerplayer0) sta DF0LOW lda #>(pointerplayer0) sta DF0HI lda player0x and #7 tay ldx MaskDataL,y .applymaskL sax DF0WRITE dec player0height bne .applymaskL end return maskR asm lda #<(pointerplayer0) sta DF0LOW lda #>(pointerplayer0) sta DF0HI lda player0x and #7 tay ldx MaskDataR,y .applymaskR sax DF0WRITE dec player0height bne .applymaskR end return data MaskDataR %11111110 %11111100 %11111000 %11110000 %11100000 %11000000 %10000000 %00000000 end data MaskDataL %01111111 %00111111 %00011111 %00001111 %00000111 %00000011 %00000001 %00000000 end Edited July 21, 2011 by ScumSoft Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted July 21, 2011 Share Posted July 21, 2011 I'm not sure how feasible it is to handle single, double, and quad-width sprites as the code could get a little convoluted. Chun Li's routines already handle all 3 sizes. Feel free to use them in bB. They work by using the X position to determine which side to mask, using a range of -7 thru 160 if I recall correctly. Quote Link to comment Share on other sites More sharing options...
+batari Posted July 23, 2011 Share Posted July 23, 2011 I will take a look. I'm still not sure about double and quad-width sprites as it's impossible to mask them smoothly without using other objects to hide part of them. Quote Link to comment Share on other sites More sharing options...
