sometimes99er Posted July 20, 2011 Share Posted July 20, 2011 (edited) Here's a little XB demo. Nothing too beautiful about it. First of all I'm having a little brick. It's 2 characters wide, and 1 character high. Has a bit of 3D effect inside. And then there's a shadow from the brick. An effect often used in those breakout style games. The bricks are put randomly to the screen. The shadow are then put to the screen too. The shadow has to respect a few rules though. First of all the shadow is only drawn if there's not a brick there. Secondly if there's already some shadow there, the old and new shadows has to merge together. - Like if there's some shadow there from a brick above, and we're trying to put some shadow to the right of a brick, then that screen character has to contain shadows from both bricks. This is done using bit mask operations. Nothing too clever about this, but a nice touch anyhow. The code could probably be much better with different aspects in mind. Readability, speed, comments, structure, compactness, cleverness etc. Some of these probably contradict the other - much like real life. Anyway, if you have any questions, go ahead, and I'll try to dissect and explain. This message only has the code included below, no graphics, animation or video for now. Edit. My code and smiley has disappeared. And I can't find my original code in my archive. Edited April 11, 2021 by sometimes99er Forum update or something 1 Quote Link to comment Share on other sites More sharing options...
matthew180 Posted July 20, 2011 Share Posted July 20, 2011 Pretty cool! I changed the shadow to 1 pixel though, 2 pixels seemed too big. It would also be nice to have a gray shadow to be more subtle, but that would mean removing the white bricks. I tried to round the corners, but forgot that the background color of the character would show through instead of the screen background. Doh! :-) Use the TI BASIC Translator to make XB code (http://codehackcreate.com/archives/237) CALL CLEAR:: CALL SCREEN(14) // Shadow masks P1$(0)="0000":: P1$(1)="8000":: P1$(2)="3F00":: P1$(3)="FF00" P2$(0)="0":: P2$(1)="80808080808" // Define characters FOR B=0 TO 1:: FOR A=0 TO 3:: CALL CHAR(32 + A + B * 4, P1$(A) & P2$(B)):: NEXT A:: NEXT B // Set up colors and define brick characters. The definition // is for the dark color of the brick. FOR A=0 TO 6:: CALL CHAR(40+A*8, "0000000000003F7F010303030303FFFF") READ FC, BC:: CALL COLOR(2+A, FC, BC):: NEXT A DATA 3,4,5,6,7,9,9,10,11,12,13,3,15,16 RandomNumber: R=INT(RND*23)+1:: C=INT(RND*30)+1:: CALL GCHAR(R, C, G):: IF G>39 THEN RandomNumber CALL GCHAR(R, C+1, G):: IF G>39 THEN RandomNumber I=INT(RND*7)*8+40:: CALL HCHAR(R, C, I):: CALL HCHAR(R, C+1, I+1) // Check to the right CheckRight: CALL GCHAR(R, C+2, G):: IF G>38 THEN CheckDown CALL HCHAR(R, C+2, G OR 4) CheckDown: CALL GCHAR(R+1, C, G):: IF G>38 THEN CheckCorner CALL HCHAR(R+1, C, G OR 2) CheckCorner: CALL GCHAR(R+1, C+1, G):: IF G>38 THEN CheckDiagonal CALL HCHAR(R+1, C+1, G OR 3) CheckDiagonal: CALL GCHAR(R+1, C+2, G):: IF G>38 THEN RandomNumber CALL HCHAR(R+1, C+2, G OR 1):: GOTO RandomNumber 2 Quote Link to comment Share on other sites More sharing options...
idflyfish Posted July 20, 2011 Share Posted July 20, 2011 Very nice...I like it. I want to see a TurboForth version now...Willsy? 1 Quote Link to comment Share on other sites More sharing options...
lucien2 Posted July 20, 2011 Share Posted July 20, 2011 The code could probably be much better with different aspects in mind. Readability, speed, comments, structure, compactness, cleverness etc. Nice and clever. I don't know how you could do it much more compact. 1 Quote Link to comment Share on other sites More sharing options...
JonnyBritish Posted July 20, 2011 Share Posted July 20, 2011 The code could probably be much better with different aspects in mind. Readability, speed, comments, structure, compactness, cleverness etc. Nice and clever. I don't know how you could do it much more compact. Added screenshot 1 Quote Link to comment Share on other sites More sharing options...
sometimes99er Posted July 20, 2011 Author Share Posted July 20, 2011 (edited) @matthew180 Hehe, the shadow was one pixel to start with. Also a more subtle shadow was on my mind (white background and grey shadow). This is one of a hundred or more small sketches for basically trying to squish something out of GM1 (standard graphic mode). Your bit twiddling from the odd or even thread was the reason this sketch suddenly went XB kaboom. Thanks for feedback, and thanks for taking the time to break it down so nicely with comments and white space. Nice utility you got there for sure. @idflyfish & @Willsy Thanks, and absolutely. A TurboForth version would be nice. Sort of maybe learning by example. Feel free to use any of my TI work as basis for TF examples. @lucien2 Thanks. Well, lines from 200 and on, kind of asks for a subroutine. It would make it a bit more compact, and/but at a minor cost of speed. @JonnyBritish Thanks for the screenshot. Edited July 20, 2011 by sometimes99er Quote Link to comment Share on other sites More sharing options...
lucien2 Posted July 21, 2011 Share Posted July 21, 2011 In GPL: GROM >C000 DATA >AA00,>0100,>0000 DATA MENU DATA >0000,>0000,>0000,>0000 MENU DATA >0000 DATA START STRI 'BRICKS' RND EQU >8378 P1 DATA >0000,>C0C0,>3F3F,>FFFF P2 DATA >0000,>0000,>0000 DATA >C0C0,>C0C0,>C0C0 P3 DATA >0000,>0000,>0000,>3F7F DATA >0103,>0303,>0303,>FFFF COL BYTE >10,>23,>45,>68 BYTE >89,>AB,>C2,>EF A EQU >8300 B EQU >8301 IH EQU >8302 IL EQU >8303 VIH EQU >8304 VIL EQU >8305 R EQU >8306 C EQU >8307 GH EQU >8308 GL EQU >8309 START BACK 13 * SHADOW PATTERNS CLR @A CLR @B CLR @IH CLR @VIH L1 ST @B,@VIL SLL 2,@VIL ADD @A,@VIL SLL 3,@VIL ST @A,@IL SLL 1,@IL MOVE 2,G@P1(@IH),V@>900(@VIH) INCT @VIL ST @B,@IH MUL 6,@IH MOVE 6,G@P2(@IH),V@>900(@VIH) INC @A CGE 4,@A BR L1 CLR @A INC @B CGE 2,@B BR L1 * BRICK PATTERNS DCLR @IH L2 MOVE 16,G@P3,V@>940(@IH) DADD 64,@IH DCGE 7*64,@IH BR L2 * COLORS MOVE 8,G@COL,V@>384 * MAIN LOOP L3 * RANDOM POSITION RAND 22 ST @RND,@R RAND 29 ST @RND,@C ST @R,@VIL CLR @VIH DSLL 5,@VIH DADD @C,@VIL * IS IT FREE? DST V*VIH,@GH CGT 39,@GH BS L3 CGT 39,@GL BS L3 * DRAW BRICK RAND 6 ST @RND,@IL SLL 3,@IL ADD 40,@IL ST @IL,V*VIH INC @IL DINC @VIH ST @IL,V*VIH * DRAW SHADOWS DINC @VIH ST 4,@A CALL SHADOW DADD 30,@VIH ST 2,@A CALL SHADOW DINC @VIH ST 3,@A CALL SHADOW DINC @VIH ST 1,@A CALL SHADOW B L3 * END MAIN LOOP * DRAW SHADOW SHADOW ST V*VIH,@GL CGT 38,@GL BS SHADO0 OR @A,@GL ST @GL,V*VIH SHADO0 RTN END 1 Quote Link to comment Share on other sites More sharing options...
sometimes99er Posted July 21, 2011 Author Share Posted July 21, 2011 @lucien2 Wow ! Excellente. That doesn't look too difficult - to read and understand - to actually program it is something else. Reading Forth code is much more difficult - to me that is. I don't know how to compile and execute the GPL code. Is it easy ? Emulation only will do for me. Quote Link to comment Share on other sites More sharing options...
lucien2 Posted July 21, 2011 Share Posted July 21, 2011 I don't know how to compile and execute the GPL code. GPLHOW2 1 Quote Link to comment Share on other sites More sharing options...
sometimes99er Posted July 21, 2011 Author Share Posted July 21, 2011 GPLHOW2 Okay, thanks. Doesn't look like a load, ready, fire and enjoy thing. Quote Link to comment Share on other sites More sharing options...
Willsy Posted July 21, 2011 Share Posted July 21, 2011 (edited) Here it is in TurboForth: : SHAPE1 DATA 4 $C0C0 0 0 0 33 DCHAR ; SHAPE1 : SHAPE2 DATA 4 $3F3F 0 0 0 34 DCHAR ; SHAPE2 : SHAPE3 DATA 4 $FFFF 0 0 0 35 DCHAR ; SHAPE3 : SHAPE4 DATA 4 0 $C0C0 $C0C0 $C0C0 36 DCHAR ; SHAPE4 : SHAPE5 DATA 4 $C0C0 $C0C0 $C0C0 $C0C0 37 DCHAR ; SHAPE5 : SHAPE6 DATA 4 $3F3F $C0C0 $C0C0 $C0C0 38 DCHAR ; SHAPE6 : SHAPE7 DATA 4 $FFFF $C0C0 $C0C0 $C0C0 39 DCHAR ; SHAPE7 : SHAPE8 DATA 8 $0000 $0000 $0000 $3F7F $0103 $0303 $0303 $FFFF ; CREATE COLORS 2 C, 3 C, 4 C, 5 C, 6 C, 8 C, 8 C, 9 C, 10 C, 11 C, 12 C, 2 C, 14 C, 15 C, : INIT 1 GMODE 13 SCREEN 4 1 0 COLOR 7 0 DO \ define bricks and set colours from colour table... SHAPE8 I 8 * 40 + DCHAR I 5 + COLORS I CELLS + DUP C@ SWAP 1+ C@ COLOR LOOP ; 0 VALUE SEED $8379 V@ TO SEED : RND SEED 31421 * 6927 @ + DUP TO SEED ; : 3DROP COMPILE DROP COMPILE 2DROP ; IMMEDIATE 0 VALUE R 0 VALUE C 0 VALUE BRICK : MAIN-LOOP INIT BEGIN BEGIN RND 23 MOD TO R RND 30 MOD TO C R C GCHAR 38 < R C 1+ GCHAR 38 < AND UNTIL RND 7 MOD 8 * 40 + TO BRICK R C BRICK 1 HCHAR R C 1+ BRICK 1+ 1 HCHAR \ do shadow tests... R C 2+ 2DUP GCHAR DUP 39 < IF 4 OR 1 HCHAR ELSE 3DROP THEN R 1+ C 2DUP GCHAR DUP 39 < IF 2 OR 1 HCHAR ELSE 3DROP THEN R 1+ C 1+ 2DUP GCHAR DUP 39 < IF 3 OR 1 HCHAR ELSE 3DROP THEN R 1+ C 2+ 2DUP GCHAR DUP 39 < IF 1 OR 1 HCHAR ELSE 3DROP THEN AGAIN ; MAIN-LOOP http://www.youtube.com/watch?v=CUP9vu0lNB0 Hope you like it. [Edit: No CPU overdrive was used in the above videos. Just paste the code into classic99 to try it out. Enjoy] Edited July 21, 2011 by Willsy 1 Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted July 22, 2011 Share Posted July 22, 2011 How about in LOGO II?? 1 Quote Link to comment Share on other sites More sharing options...
sometimes99er Posted July 22, 2011 Author Share Posted July 22, 2011 @Willsy Thanks my friend. Just read the TF code once, and I got most of it, apart from some C@, V@, @ and COMPILE stuff. Where would one look this up most easily ? Quote Link to comment Share on other sites More sharing options...
Willsy Posted July 22, 2011 Share Posted July 22, 2011 @Willsy Thanks my friend. Just read the TF code once, and I got most of it, apart from some C@, V@, @ and COMPILE stuff. Where would one look this up most easily ? Good morning! Ok, a quick explanation of the code. I'll skip the definition of the graphics, I'm sure you understand that. Let's look at the color data: CREATE COLORS 2 C, 3 C, 4 C, etc.... CREATE simply creates an entry in dictionary with the name that follows CREATE. So, in the above code, a dictionary entry called COLORS is created. When we *execute* COLORS (by simply using it's name in the code) it is programmed to simply push the address of the word (the address of the 'code space') of the word. Who programs COLORS to do this? CREATE does! (You could think of CREATE as a class and COLORS as an object of type CREATE, with one single method - to push the address of its code-space). Ok, I hope that wasn't too hard to understand. Next, we use C, ("compile a char") to 'compile' numbers (called literals) directly into memory. So... 2 C, 3 C, 4 C, 5 C, 6 C, 8 C, 8 C, ...compiles 2 3 4 5 6 8 and 8 (as bytes) into memory. TF takes care of where they will be compiled (there is an internal pointer called HERE which always points to the *next* compilation address - C, uses HERE to get the address, and increments HERE by 1 afterwards). So, by "compiling" those numbers *directly after* COLORS, we find that when we execute COLORS the address returned is the address of first byte of the numbers we just compiled. What we just did is *exactly* the same as this in machine code: colors data 2,3,4,5,6,8,8 So, using simple terms, we compiled a list of bytes, and COLORS returns the address of the start of that list. Try this in TF: CREATE LIST 1 C, 2 C, 3 C, 4 C, 5 C, 6 C, : TEST LIST 6 0 DO DUP I + C@ . LOOP DROP ; C@ means "fetch byte". Words in Forth have prototypes, a bit like C, but their format is different, because Forth is stack based. Forth "prototypes" are called "stack signatures". Here is the stack signature for C@: C@: address -- byte The important thing in a time signature is the -- symbol. The stuff on the left shows the stack BEFORE the word executes. The stuff on the right shows the stack AFTER the word executes. So, we can see that C@ expects an address on the stack, and replaces that address with the value (byte) at that address. Here is SWAP: SWAP: a b -- b a So, swap takes the top two stack items, a and b and exchanges them, giving us b a. V@ is the same as C@ - however, it reads a byte from VDP: V@: vdp_address -- byte_value VALUEs are very much like variables: 9900 VALUE TI ok:0 TI . 9900 ok:0 50 TO TI ok:0 TI . 50 ok:0 1+ and 2+ add 1 and two to the top-of-stack: 1+: a -- a+1 2+: a -- a+2 2DUP DUPlicates the top TWO items: 2DUP: a b -- a b a b The word 3DROP needs special explanation. 3DROP is a "compiling" word. Compiling words are quite unique to Forth, so it usually takes people a while to get their head around them. The first thing to notice is the word IMMEDIATE after the end of the definition of 3DROP - this is very important. When 3DROP is compiled into memory, nothing very special happens. It just gets compiled like any other word. However, when 3DROP is referenced in another word, something very special happens.... Normally, when the compiler is compiling a word, it just compiles a call to each word that it finds. However, if the word referenced is marked as IMMEDIATE, rather than compiling it, the compiler instead EXECUTES the word. So, when the compiler is compiling MAIN-LOOP it sees a reference to 3DROP and instead of compiling 3DROP, it executes it. Ok, so what happens then? Well, 3DROP actually compiles some words itself into memory (pointed to by HERE). It compiles a DROP then a 2DROP. Where do these get compiled to? They get compiled into the current location in MAIN-LOOP because that was where HERE was pointing to when 3DROP executed! So, 3DROP is a macro that compiles its payload into the "current definition". So, MAIN-LOOP looks like this in the source code: IF 4 OR 1 HCHAR ELSE 3DROP THEN However, in memory, it looks like this: IF 4 OR 1 HCHAR ELSE DROP 2DROP THEN Hope this helps to de-mystify Forth a little bit. It really is very simple. It's like a "super machine-code" - very very simple. 1 Quote Link to comment Share on other sites More sharing options...
sometimes99er Posted July 22, 2011 Author Share Posted July 22, 2011 GPLHOW2 Okay, thanks. Doesn't look like a load, ready, fire and enjoy thing. I might not have been all that appreciative, or should I say, I haven't got the free time to dig into it as is. I'll look into it sooner or later, to, at least produce a GROM - just to see how it performs compared with TurboForth, knowing that they could probably both be optimized etc. Any feelings about how these two beasts (would) compare ? I think Mini Memory was a fine extension back then. Making more power available for common man or poor man. Candidates for built in or small extensions might have been GPL and Forth programming langauges. Mini Mem did it with a 4K RAM in the cart, and I guess Forth would've been able to do something similar ? Would a GPL cart with no RAM (other than 256 bytes Scratch and 16 K VDP) have been a possibility ? How about in LOGO II?? Personally I don't think it's very hot, but sure, would be nice to see it. @Willsy Thanks my friend. Just read the TF code once, and I got most of it, apart from some C@, V@, @ and COMPILE stuff. Where would one look this up most easily ? Good morning! Hehe, thanks for the explanation and a good afternoon to you. Think I understand all - will have to experiment later. Quote Link to comment Share on other sites More sharing options...
lucien2 Posted July 22, 2011 Share Posted July 22, 2011 Any feelings about how these two beasts (would) compare ? I changed the TF code from this BEGIN RND 23 MOD TO R RND 30 MOD TO C R C GCHAR 38 < R C 1+ GCHAR 38 < AND UNTIL to this BEGIN RND 23 MOD TO R RND 30 MOD TO C R C GCHAR 40 < R C 1+ GCHAR 40 < AND UNTIL to fill the holes, but there are still two holes that are not filled (maybe the random routine?). http://www.youtube.com/watch?v=tNDbEwglJIo GPLHOW2 Okay, thanks. Doesn't look like a load, ready, fire and enjoy thing. LOL, the edit/compile/run cycle in GPL is just two steps longer than assembly. 1. Edit 2. Assemble 3. Run "GPL@LOADER" 4. Load object into GRAM 5. Run from master title menu 2 Quote Link to comment Share on other sites More sharing options...
Willsy Posted July 22, 2011 Share Posted July 22, 2011 I changed the TF code from this BEGIN RND 23 MOD TO R RND 30 MOD TO C R C GCHAR 38 < R C 1+ GCHAR 38 < AND UNTIL to this BEGIN RND 23 MOD TO R RND 30 MOD TO C R C GCHAR 40 < R C 1+ GCHAR 40 < AND UNTIL to fill the holes, but there are still two holes that are not filled (maybe the random routine?). Yeah, it's the RND routine, which is just reading from memory addresses. I'm no mathematician! GPL and TF seem to be very very close indeed - they looked exactly the same speed to me. I thought TF would be a little bit faster than GPL, but it looks about the same. Mark 1 Quote Link to comment Share on other sites More sharing options...
sometimes99er Posted July 22, 2011 Author Share Posted July 22, 2011 @lucien2 Excellent video. And thanks for the how2 overview. Should go back and watch the video. The 6+ minutes scared me. GPL and TF seem to be very very close indeed - they looked exactly the same speed to me. I thought TF would be a little bit faster than GPL, but it looks about the same. Street cred to both languages/implementations. Me too, I thought TF would be maybe at least twice as fast, but I guess GPL surprises a bit. Quote Link to comment Share on other sites More sharing options...
Willsy Posted July 22, 2011 Share Posted July 22, 2011 @lucien2 Excellent video. And thanks for the how2 overview. Should go back and watch the video. The 6+ minutes scared me. GPL and TF seem to be very very close indeed - they looked exactly the same speed to me. I thought TF would be a little bit faster than GPL, but it looks about the same. Street cred to both languages/implementations. Me too, I thought TF would be maybe at least twice as fast, but I guess GPL surprises a bit. It certainly does surprise! Would it run at that speed in a real console, running from GROM? 1 Quote Link to comment Share on other sites More sharing options...
RXB Posted July 23, 2011 Share Posted July 23, 2011 (edited) GPLHOW2 Okay, thanks. Doesn't look like a load, ready, fire and enjoy thing. The syntax for GPL is very much like XB. XB 10 X=200 GPL L10 ST 200,@X The L10 is a label line 10 in XB and ST is STore, so the only other difference is the @ which means AT You can also do X EQU 200 Which is like a constant instead of the ST that is more like a variable. Now Assembly only has 16 Registers and GPL only has 256 bytes of Scratch Pad but the same program in GPL will use less storage and variables then XB or Assembly. Only Forth is more compact, but again much more complicated to learn. Edited July 23, 2011 by RXB Quote Link to comment Share on other sites More sharing options...
RXB Posted July 23, 2011 Share Posted July 23, 2011 (edited) LOL, the edit/compile/run cycle in GPL is just two steps longer than assembly. 1. Edit 2. Assemble 3. Run "GPL@LOADER" 4. Load object into GRAM 5. Run from master title menu Yes and you have another step with CSAVE to create GRAM Module Files. But once that is done you can have a Module always set up and run permanently. That is something that Assembly or Forth could never do. Be instantly up and running from menu screen even if the computer is turned off and on. That more then pays for the trouble. If not for Cartidges and that Slot there would be no TurboForth cart. By the way I need to order one. Edited July 23, 2011 by RXB Quote Link to comment Share on other sites More sharing options...
JonnyBritish Posted July 23, 2011 Share Posted July 23, 2011 Interesting stuff.. this is almost starting to read like GPL vs Turboforth trash talk :-) Question is could you write GPL in TurboForth! 1 Quote Link to comment Share on other sites More sharing options...
marc.hull Posted July 23, 2011 Share Posted July 23, 2011 Yes and you have another step with CSAVE to create GRAM Module Files. But once that is done you can have a Module always set up and run permanently. That is something that Assembly or Forth could never do. Be instantly up and running from menu screen even if the computer is turned off and on. That more then pays for the trouble. If not for Cartidges and that Slot there would be no TurboForth cart. By the way I need to order one. Hmmmm... every time I turn on my TI I am instantly greeted with "Menu" (assembly program) and can select 24 assembly or XBASIC program to run instantly at the touch of a button. No loading required (on my part anyway.) Quote Link to comment Share on other sites More sharing options...
RXB Posted July 24, 2011 Share Posted July 24, 2011 Yes and you have another step with CSAVE to create GRAM Module Files. But once that is done you can have a Module always set up and run permanently. That is something that Assembly or Forth could never do. Be instantly up and running from menu screen even if the computer is turned off and on. That more then pays for the trouble. If not for Cartidges and that Slot there would be no TurboForth cart. By the way I need to order one. Hmmmm... every time I turn on my TI I am instantly greeted with "Menu" (assembly program) and can select 24 assembly or XBASIC program to run instantly at the touch of a button. No loading required (on my part anyway.) And where does this reside? Afraid you missed my point. The TI was built to access 640K of GROM from the cartridge slot in 1979. This was just the console and nothing else. Really what can you do with 8K Cartridge RAM and just a console? (Answer: Sell cartriges like hot cakes just like TI did. Hottest item they sold, and attempted to shut down others that created them.) I fully understand things change but give credit to what made this possible. When the TI99 was introduced it was the GROM slot that sold the machine not the DISK programs or TAPE programs. Later DISK and TAPE took off. Everyone started with EA/MM/XB/LOGO/PASCAL or the Basic built in. All of these are GPL. Just please give credit instead of dissing GROM. All of these hacks copy what GPL does right out of the box since it was introduced. Quote Link to comment Share on other sites More sharing options...
marc.hull Posted July 24, 2011 Share Posted July 24, 2011 Yes and you have another step with CSAVE to create GRAM Module Files. But once that is done you can have a Module always set up and run permanently. That is something that Assembly or Forth could never do. Be instantly up and running from menu screen even if the computer is turned off and on. That more then pays for the trouble. If not for Cartidges and that Slot there would be no TurboForth cart. By the way I need to order one. Hmmmm... every time I turn on my TI I am instantly greeted with "Menu" (assembly program) and can select 24 assembly or XBASIC program to run instantly at the touch of a button. No loading required (on my part anyway.) And where does this reside? Afraid you missed my point. The TI was built to access 640K of GROM from the cartridge slot in 1979. This was just the console and nothing else. Really what can you do with 8K Cartridge RAM and just a console? (Answer: Sell cartriges like hot cakes just like TI did. Hottest item they sold, and attempted to shut down others that created them.) I fully understand things change but give credit to what made this possible. When the TI99 was introduced it was the GROM slot that sold the machine not the DISK programs or TAPE programs. Later DISK and TAPE took off. Everyone started with EA/MM/XB/LOGO/PASCAL or the Basic built in. All of these are GPL. Just please give credit instead of dissing GROM. All of these hacks copy what GPL does right out of the box since it was introduced. Quote Link to comment Share on other sites More sharing options...
