wt808 Posted July 26, 2011 Share Posted July 26, 2011 About 6 years ago, I converted a 5200 to use arcade controls using a multi-input adapter that I designed. I built an enclosure and top for the system, positioned and mounted the controls, and then built a small upright cabinet to support it and an extra VGA monitor I had laying around. The 5200 system sits in the white-colored box under the controls and over the coin door. Part of the reason for designing the compact 5200 mainboard was to eliminate the noisy cooling fan and for more room inside the enclosure for 4-/8-way switchable digital joysticks (a 4-way is needed for Pac-Man). The box is about the size of the original console shell. The lower area of the cabinet behind the coin door is storage for cartridges, controllers, speakers, Svideo-to-VGA adapter. I made an A/V adapter to output Svideo and line-level audio, and made a low profile 16-in-1 flash cartridge to fit in the enclosure. The left knob on the front selects the active control for both players: digital joystick, paddle, trackball, and analog PC joystick. A small LED above the active control lights up when it is selected. The right black button on the front is the relocated 5200 power switch, now a Happ momentary pushbutton switch. The lower fire buttons have switchable Turbo fire via a rocker switch for each player. There are 2 upper fire buttons for each player to accomodate right- and left-handed players. The keypads are surplus 3x4 matrix for a pay phone. I can't use the overlays. The central rocker switch above the trackball assigns the trackball to player 1 or player 2 (which isn't used since the trackball is expected to be connected to port 1 as I later found out). The trackball connects to an adapter which converts the signal to both connectors on the input adapter for the original 5200 controllers. Shortly after, I designed V2 of the input adapter but never finished the firmware. Here's V2 connected to the compact 5200 mainboard. In addition to all of the controls supported by V1, it also takes 2600 joysticks and has the Happ trackball adapter built in (tall white connector in the middle). This allows me to keep the 5200 controllers connected without having to disconnect the trackball. The compact 5200 mainboard uses the same port spacing as the original mainboard, so the multi-input adapters plug right in. For a 4-port, I can install 2 adapters to build a 4 player system. 12 Quote Link to comment Share on other sites More sharing options...
bohoki Posted July 26, 2011 Share Posted July 26, 2011 neat although i find a 5200 in any other condition than as atari intended slightly repugnant but hey its your stuff far out man Quote Link to comment Share on other sites More sharing options...
Jr. Pac Posted July 26, 2011 Share Posted July 26, 2011 I love it! As if the 5200 and the trackball weren't big enough? Quote Link to comment Share on other sites More sharing options...
toptenmaterial Posted July 26, 2011 Share Posted July 26, 2011 You are very talented!! Quote Link to comment Share on other sites More sharing options...
BassGuitari Posted July 26, 2011 Share Posted July 26, 2011 You, sir, are the MAN. Incredible work! +1 Quote Link to comment Share on other sites More sharing options...
wt808 Posted July 26, 2011 Author Share Posted July 26, 2011 neat although i find a 5200 in any other condition than as atari intended slightly repugnant Yes but I find a 5200 sent to the e-waste grinders even more repugnant! No modifications were made to the 5200 mainboard except for the relocated power switch in which the original switch was broken. Everything is socketed, plug-in, and J-hooks and can be easily returned to the original configuration. The big tangle of wires in the photo goes to the adapter, not the mainboard, and the adapter simply slides onto both controller ports. The donor mainboard for the compact 5200 was something that I rescued off of eBay. Looked like it had been in a flood, no one bid on it, and it probably would've been sent to e-waste recycling. I have another 4-port console that I picked up cheap because the RF adapter was broken, controllers missing, and the owner had no other way to test and sold it "as-is". The motherboard is delaminating and has bubbly traces, RF connectors corroded, but I bet the chips are fine. 2 Quote Link to comment Share on other sites More sharing options...
Goochman Posted July 26, 2011 Share Posted July 26, 2011 Ok how much for one - Ill sacrifice owning a modified 5200 Quote Link to comment Share on other sites More sharing options...
Vic George 2K3 Posted August 10, 2011 Share Posted August 10, 2011 Not bad, even without the arcade machine bling. Quote Link to comment Share on other sites More sharing options...
wt808 Posted August 14, 2013 Author Share Posted August 14, 2013 Fresh paint, and size comparison 6 Quote Link to comment Share on other sites More sharing options...
thegamezmaster Posted August 14, 2013 Share Posted August 14, 2013 Very nice work. Wish I was that talented! Quote Link to comment Share on other sites More sharing options...
YANDMAN Posted August 14, 2013 Share Posted August 14, 2013 Fresh paint, and size comparison Man as a custom builder myself i just wanna say fantastic job, That controller is awesome, Why not make a proper arcade cabinet and saddle all these controls into it, it would easily fit on a control panel and finished properly in 5200 colour scheme would look amazing, if i had room i would build a 7800 cabinet but space in my home arcade is running out and i already have several in the pipeline, great work though you should be really pleased with what youve achieved here Quote Link to comment Share on other sites More sharing options...
wt808 Posted August 14, 2013 Author Share Posted August 14, 2013 Thanks guys. Why not make a proper arcade cabinet and saddle all these controls into it, it would easily fit on a control panel and finished properly in 5200 colour scheme would look amazing Here it is docked with the modular mini cabinet shown in the first post. The top monitor section slides off with the monitor inside so it can be moved easily. I'm hoping that the CRT dies and I'll get an LCD that I can mount at an angle and rebuild the upper section to look more like an arcade cabinet. 3 Quote Link to comment Share on other sites More sharing options...
walter_J64bit Posted August 17, 2013 Share Posted August 17, 2013 WoW! Quote Link to comment Share on other sites More sharing options...
7800 Posted August 17, 2013 Share Posted August 17, 2013 Any chance of you making another one of these "Multi Input Adapters" for me to purchase from you? I desperately want an arcade controller for my 5200. I've been trying to get an answer to the, "Custom Arcade Stick for 5200" question on here for a while with no luck... and here it is. I can build the stick, I just need your adapter. Quote Link to comment Share on other sites More sharing options...
wt808 Posted August 17, 2013 Author Share Posted August 17, 2013 No plans to build and sell the current form, but I will be revisiting the adapter project shortly. Quote Link to comment Share on other sites More sharing options...
