boxpressed Posted August 1, 2011 Share Posted August 1, 2011 At the risk of heresy, I'll admit to being curious about whether I can play my 2600 and other RF / switch box consoles on my LCD monitor via a VGA box. I do have a CRT for retro consoles, but desk space is becoming a premium. I have one of these: K-World 1440 It works great with my PS2. I've tried to hook up my 2600 to the coax input on the VGA box using the RCA-coax adapter, but I can't get a signal on my monitor. I was just wondering if this setup is even possible since I don't know much about the types of signals that are being output by the 2600 and can be received/converted by the VGA box. Thanks in advance! Quote Link to comment Share on other sites More sharing options...
boxpressed Posted August 1, 2011 Author Share Posted August 1, 2011 (edited) Some pics to clarify. I have one of these: and one of these: No video signal on the monitor with the 2600. Works fine with the PS2 when I have S-Video input via the included dongle (not shown). Edited August 1, 2011 by boxpressed Quote Link to comment Share on other sites More sharing options...
Rex Dart Posted August 1, 2011 Share Posted August 1, 2011 Cheap-ish VGA box probably just can't deal with the 2600's non-standard output. You'd have better luck converting to VGA if you do a Composite video mod to the 2600, then convert that to VGA. Still may not work, though. Quote Link to comment Share on other sites More sharing options...
boxpressed Posted August 1, 2011 Author Share Posted August 1, 2011 Cheap-ish VGA box probably just can't deal with the 2600's non-standard output. You'd have better luck converting to VGA if you do a Composite video mod to the 2600, then convert that to VGA. Still may not work, though. OK. I was wondering whether the 2600 had non-standard output. I will unpack my Odyssey 2 later today and see if it can't output to the box. My dream of one VGA box to play them all may be just that -- a dream. I might go down the HDTV-as-monitor route now... Quote Link to comment Share on other sites More sharing options...
keilbaca Posted August 1, 2011 Share Posted August 1, 2011 Cheap-ish VGA box probably just can't deal with the 2600's non-standard output. You'd have better luck converting to VGA if you do a Composite video mod to the 2600, then convert that to VGA. Still may not work, though. OK. I was wondering whether the 2600 had non-standard output. I will unpack my Odyssey 2 later today and see if it can't output to the box. My dream of one VGA box to play them all may be just that -- a dream. I might go down the HDTV-as-monitor route now... You *can* use a VCR if you like to play the nonstandard devices on the monitor. Quote Link to comment Share on other sites More sharing options...
Rex Dart Posted August 1, 2011 Share Posted August 1, 2011 Yeah, you can definitely try running the RF through anything that converts RF to Composite, like a VCR. Usually has good results. Quote Link to comment Share on other sites More sharing options...
boxpressed Posted August 1, 2011 Author Share Posted August 1, 2011 I was wondering about that. Someone had mentioned in passing the possibility of using a VCR. Guess I shouldn't have recycled my VCR with S-Video output! (It was eating my tapes, what could I do?) So just to be sure, I would hook it up this way: 2600 > VCR coax TV-in (with RCA/coax adapter) VCR coax/composite/s-video out (can't remember what my last VCR has for outputs) > VGA box? Thanks for the advice -- I'm eager to try this solution once I get home. Quote Link to comment Share on other sites More sharing options...
keilbaca Posted August 1, 2011 Share Posted August 1, 2011 I was wondering about that. Someone had mentioned in passing the possibility of using a VCR. Guess I shouldn't have recycled my VCR with S-Video output! (It was eating my tapes, what could I do?) So just to be sure, I would hook it up this way: 2600 > VCR coax TV-in (with RCA/coax adapter) VCR coax/composite/s-video out (can't remember what my last VCR has for outputs) > VGA box? Thanks for the advice -- I'm eager to try this solution once I get home. That's exactly right. Quote Link to comment Share on other sites More sharing options...
boxpressed Posted August 1, 2011 Author Share Posted August 1, 2011 Using the VCR did the trick. The image looks about as I had expected -- a tad blurry and washed out. Worst of all are the black, vertical bars that you see in between the colored pixels. No lag at all, however. A fun experiment, but I think I may go back to the CRT to enjoy the excellent H6 RF output. Quote Link to comment Share on other sites More sharing options...
Rex Dart Posted August 1, 2011 Share Posted August 1, 2011 Oh, I figured you were using a CRT monitor with VGA... Yeah, CRT's the only way to play classic systems / anything with less than 480p resolution. Quote Link to comment Share on other sites More sharing options...
