Deteacher Posted August 22, 2011 Share Posted August 22, 2011 177,700! Made it to level 8! I "mastered" the cannon level. Here's my tip for the cannons: As you approach the first cannon (the one that shoots from right to left) get Wile E. Coyote as close to you as possible. That way, the cannon will shoot him (sometimes several times, earning lots of points.) If he gets shot, try to keep the cannon on screen so it will shoot him multiple times. Each time he's hit, you score 200 extra points. Once he gets out of the way of the cannon, take the top road (don't worry about missing bird seed. Staying alive is more important.) Use the timing tip from the earlier post for your best chance of getting past the cannon, but while you're on the top road, keep pressing left. You won't go anywhere, but When you press left, Wile E. moves away from you. When you see your opening, slip by the cannon, but try to keep it on screen, so it shoots Wile E. (hopefully multiple times again.) I racked up close to 2000 points one time, letting the cannon blast away at the coyote. Wash, rinse, repeat through the level. I think the sequence plays through 4 times before the end of the level. It'll take some practice and some luck. Level 5 is more steel shot and land mines. Just keep running circles around Wile E. and you'll be fine. Level 6 is the boulders. Patience is the key to this level. Go around Wile E. and press on the right side until you have a clear path past the boulders. This level takes the longest because you have to be patient for the openings, sometimes. Level 7 is more steel shot and land mines. Level 8 is more cannons. Hoping to beat level 8 and see what happens. Probably just starts over at level 1. 1 Quote Link to comment Share on other sites More sharing options...
Miss 2600 Posted August 22, 2011 Share Posted August 22, 2011 (edited) Made it to level 8! I "mastered" the cannon level. Here's my tip for the cannons: Wow! I've only managed to dabble in level 4 a few times. When you got to level 5 the first time, were you able to get to level 8 right away on that same game or was it a gradual progression? Edited August 22, 2011 by Miss 2600 Quote Link to comment Share on other sites More sharing options...
Deteacher Posted August 22, 2011 Share Posted August 22, 2011 (edited) Made it to level 8! I "mastered" the cannon level. Here's my tip for the cannons: Wow! I've only managed to dabble in level 4 a few times. When you got to level 5 the first time, were you able to get to level 8 right away on that same game or was it a gradual progression? No, it took a couple games to really get the hang of the cannons...and a couple more to figure out the boulders. The steel shot levels are really easy for me now. The trick is to literally run circles around Wile E. Jump over the mines and let him blow himself up, too. Edited August 22, 2011 by Deteacher Quote Link to comment Share on other sites More sharing options...
Miss 2600 Posted August 22, 2011 Share Posted August 22, 2011 So you run behind the coyote? I've never tried that. Quote Link to comment Share on other sites More sharing options...
Deteacher Posted August 22, 2011 Share Posted August 22, 2011 Yes. When you're running right to left and he gets close to you, swing around and run all the way to the right. When he gets close to you again, swing around again and continue on to the left. Learn to get Wile E. in line with the trucks because there are huge points to be scored that way, too. You can easily rack up 60K in points after the first level. Quote Link to comment Share on other sites More sharing options...
classicgamer_27330 Posted August 22, 2011 Share Posted August 22, 2011 48,700 no drawing for bonus. The coyote decides to go vegetarian, he and the road runner become friends and live happily ever after Quote Link to comment Share on other sites More sharing options...
oyamafamily Posted August 22, 2011 Share Posted August 22, 2011 177,700! CONGRATULATIONS, DETEACHER! THAT'S AWESOME!! :thumbsup: :thumbsup: YOU ARE SURPRISING JACOBZU7ZU7, THE CURRENT LEADER OF 2600 HSC SEASON 9 RANKING!! Quote Link to comment Share on other sites More sharing options...
Gorfy Posted August 22, 2011 Share Posted August 22, 2011 106,100 I'm getting further on level 4, but not quite all the way to the end. Quote Link to comment Share on other sites More sharing options...
Gorfy Posted August 22, 2011 Share Posted August 22, 2011 (edited) Use the timing tip from the earlier post for your best chance of getting past the cannon, but while you're on the top road, keep pressing left. Deteacher, what timing tip are you referring to? I'm getting exasperated by these canons By the way, congratulations to Deteacher and Pis for getting past level 4. Apparently, I could also use some tips on how to use the "insert quote" function Edited August 22, 2011 by Gorfy Quote Link to comment Share on other sites More sharing options...
Deteacher Posted August 22, 2011 Share Posted August 22, 2011 Use the timing tip from the earlier post for your best chance of getting past the cannon, but while you're on the top road, keep pressing left. Deteacher, what timing tip are you referring to? I'm getting exasperated by these canons By the way, congratulations to Deteacher and Pis for getting past level 4. Apparently, I could also use some tips on how to use the "insert quote" function Someone mentioned earlier about watching when the cannons fire. If they fire 2 or 3 shots in quick succession, that's when your best opportunity to go for it is. It can be frustrating, but as long as you are on the top level, pressing against the left "wall", Wile E. can't catch you. Quote Link to comment Share on other sites More sharing options...
roadrunner Posted August 22, 2011 Share Posted August 22, 2011 177,700! Really awesome score 'teach!! Quote Link to comment Share on other sites More sharing options...
Miss 2600 Posted August 23, 2011 Share Posted August 23, 2011 Now in the 80K club. 86,300 Quote Link to comment Share on other sites More sharing options...
DT Kofoed Posted August 23, 2011 Share Posted August 23, 2011 Tiny bump: 86,900. [it's been an exhausting week ] Quote Link to comment Share on other sites More sharing options...
DJT Posted August 23, 2011 Share Posted August 23, 2011 I'm with you stan! This is a historic system. Game availability is good. You owe it to video game history to own the original game and the instructions. Roms are great to mess around with...but i like the physical cart. Awesome! Let's not play it together! Hey, this isn't a Collecting Score Club, it's a High Score Club Don't we all collect? I've got over 200 carts and counting, and I generally dislike the feel of emulation as well, but we're talking about playing the games here, and a Harmony lets you do that while you wait for the game to come in the mail [almost always late!] Besides, it's custom made, limited quantity released so far, blah blah blah... Oh wait, it's a competition! Hell yeah, don't play this week and I don't have to worry about you catching up, Stan I don't have a stelladaptor The store is closed. Playing with a keyboard on my laptop is nasty. Quote Link to comment Share on other sites More sharing options...
DT Kofoed Posted August 23, 2011 Share Posted August 23, 2011 92,900 Made my personal goal, and I don't think I'll have time to crack 100K since I work tonight... also, I'd have to figure out how to survive level 4, which probably won't happen tonight! Quote Link to comment Share on other sites More sharing options...
Vocelli Posted August 23, 2011 Share Posted August 23, 2011 I felt the earth move! Craziest thing I have ever been through. Anyone else? Quote Link to comment Share on other sites More sharing options...
Deteacher Posted August 23, 2011 Share Posted August 23, 2011 I felt the earth move! Craziest thing I have ever been through. Anyone else? Wow! You must have REALLY felt that, being so close. We felt it pretty strong here in Northern DE. Quote Link to comment Share on other sites More sharing options...
Vocelli Posted August 23, 2011 Share Posted August 23, 2011 (edited) I felt the earth move! Craziest thing I have ever been through. Anyone else? Wow! You must have REALLY felt that, being so close. We felt it pretty strong here in Northern DE. Yea, the room started shaking and then it didnt stop. I ran out the door. It stopped about 30 seconds later. Very scary for me. The people I was with sat there like deer in headlights. If it would have gotten worse they would have been crushed. They made fun of me until they found out it truely was an earthquake. Then they evacuated the building. My quick Atari reflexes would have saved my life! Hail to Atari, they can save lives. Edited August 23, 2011 by Vocelli 1 Quote Link to comment Share on other sites More sharing options...
Deteacher Posted August 24, 2011 Share Posted August 24, 2011 216,600! Got past level 8! Level "9" is more steel shot and level "10" is level 2, so it looks like it just goes back to the beginning, for the most part. Oh, and you get another life at 200K. Quote Link to comment Share on other sites More sharing options...
JacobZu7zu7 Posted August 24, 2011 Share Posted August 24, 2011 I felt the earth move! Craziest thing I have ever been through. Anyone else? Wow! You must have REALLY felt that, being so close. We felt it pretty strong here in Northern DE. Yea, the room started shaking and then it didnt stop. I ran out the door. It stopped about 30 seconds later. Very scary for me. The people I was with sat there like deer in headlights. If it would have gotten worse they would have been crushed. They made fun of me until they found out it truely was an earthquake. Then they evacuated the building. My quick Atari reflexes would have saved my life! Hail to Atari, they can save lives. I felt a few tremors in the 80's before but was so long ago, not a 30 second shake LIKE THAT! More like a 5 second one. Very odd feeling, to leave is the right way to go even if it's a weak earthquake. I'd never move to Japan or LA, I'll say that. Once an elevator opened too soon, and I jumped out before it stopped... I didn't trust it, seeing a quarter of the 3rd floor passing by lol. I'm in Florida and praying the hurricane either weakens or stays east... Quote Link to comment Share on other sites More sharing options...
JacobZu7zu7 Posted August 24, 2011 Share Posted August 24, 2011 New score made it to level 6! Level 4 is much easier now for me...! but it might be too late to learn level 6. Roadrunner 116,100 My Bonus Pic... Cement truck set up to drop off cement on the street by Will-E Coyote to stop roadrunners speed, and he will use the net/cage to nab that cheeky monkey! ROADRUNNER CANNOT READ THE SIGN! ROAD CLOSED.. CEMENT TRUCK.... WAKE UP BIRD!!! Quote Link to comment Share on other sites More sharing options...
roadrunner Posted August 24, 2011 Share Posted August 24, 2011 82,100 I joined the 80k Club. No bonus because the Road Runner can never be caught! Quote Link to comment Share on other sites More sharing options...
Miss 2600 Posted August 24, 2011 Share Posted August 24, 2011 Whoever designed this game did an excellent job capturing the spirit of the cartoon. And the controls are smooth, too. This was a really fun game. I only wish I could survive longer so I can play through all the neat stuff shown in the demo. Quote Link to comment Share on other sites More sharing options...
toymailman Posted August 24, 2011 Share Posted August 24, 2011 Got to Level 6! 137,900 Quote Link to comment Share on other sites More sharing options...
toymailman Posted August 24, 2011 Share Posted August 24, 2011 The Coyote has tried to blow up the Road Runner so many times that the Road Runner becomes complacent. This time it works! Kablooey! Quote Link to comment Share on other sites More sharing options...
