Algus Posted September 23, 2011 Share Posted September 23, 2011 I picked up a pair of NES Maxes the other day and one works fine (or close to fine I guess, the disc isn't to responsive but I assume that's a common problem) but the other is giving me all kinds of strangeness. I was testing it out on Jaws and the A Button was actually functioning as Start/Pause. The D-umm "circle" and disc were doing nothing and the other buttons didn't seem to do much either. The controller is in good physical condition so I am wondering if this is something I can repair, but to be honest I don't really know how to go about doing that and I'd prefer not to risk wrecking my working Max just to see what the innards look like. Any advice or web links or anything would be super appreciated! Quote Link to comment Share on other sites More sharing options...
axh174 Posted September 30, 2011 Share Posted September 30, 2011 Hmmm, if the A button is functioning as the Start/Pause button then there's the possibility that whatever it damaged is related to the IC on the controller's main board. If your Start/Pause button is still doing its job then it could just be that the rubber pads under the buttons are destroyed, but those can be found in replacement kits. If you've never taken apart a nintendo controller before, what you'll find inside is a series of plastic buttons (the D-pad, A, B, Start and Select, obviously) and laying on top of these buttons are sections of rubber membranes (one for the D-pad, one for the A+B and one for the Start+Select) Each rubber membrane has a dome-like shape, kind of like a half bubble, which allows it to spring back into position after being depressed by the button. On the bottom of the dome is a little metal contact. When you press a button, the dome is depressed, the metal contact connects with the circuit board and completes a connection. It's a pretty simple setup. The NES Max is no different, it just has a couple extra membrane to accomodate the turbo buttons. (Pretty sure the circle button is not really a button, it just resides inside the black ring, which looks like a regular D-pad from the bottom side) Sometimes, the rubber membranes can tear and rip with use and then they no longer function correctly. These membranes can usually be bought as part of a refurbishment kit that you can find online, either on ebay or elsewhere. If the rubber membranes are intact, it could be that the metal contacts are just dirty, both on the dome undersides and on the circuit board. The circuit board contacts should be shiny, while the metal contacts on the dome undersides should be grayish-black. I've had success using an eraser to remove crud build-up. Another option that I've had success with in repairing NES Advantages is to cut a tiny circular piece of tin-foil no larger than the metal contact on the underside of the dome. Super-glue the tin foil to the metal contact and it should restore functionality (provided the membrane is intact). In any event, go ahead and take apart one of the new-used NES Max's you got. It should be painfully obvious is something is broken (so you shouldn't have to open up your working one). While in there, make sure to check the controller cord connections to the circuit board; sometimes those can break. If you have a multi-meter, use it to check for continuity between each pin on the controller jack and the circuit board. (it could be you're dealing with a bad cord!) Quote Link to comment Share on other sites More sharing options...
Game-Tech.US Posted October 2, 2011 Share Posted October 2, 2011 Yeah, its the chip, i've fixed several that did the very same thing, cords were fine, pads were clean, but the chip had to be replaced. Its the same chip thats in all the nes controllers, I had other controllers that had bad cords that I swapped with so I hadn't looked into it till now, but you can buy replacements: IC is marked 4021, mouser link, shift register, about $0.50. Quote Link to comment Share on other sites More sharing options...
abby santi Posted October 11, 2011 Share Posted October 11, 2011 Hey aka when you buy it from the site provided, are they already programmed to work once u you solder it to the nes controller board? I'm kinda new with these ic chips. Thanx in advance Quote Link to comment Share on other sites More sharing options...
Rex Dart Posted October 11, 2011 Share Posted October 11, 2011 Yeah, it's a simple chip, there's no program involved. It just does its thing & works. Quote Link to comment Share on other sites More sharing options...
abby santi Posted October 11, 2011 Share Posted October 11, 2011 Awesome man thanx a lot for you're help Quote Link to comment Share on other sites More sharing options...
