ferghead Posted September 23, 2011 Share Posted September 23, 2011 (edited) I am going through my 5200 collection to test it out, it's been awhile. I expected the stock controllers not to work, and so far they haven't disappointed me. I have 4 of the Wico controllers with the Y cable, and on a few of them, certain directions will not work for certain games (I am using the stock controllers with the Wico sticks; I don't have a Wico keypad or a Masterplay Interface, sadly). I played Pole Position without any problems. Then I played Pitfall 2 and all four directions were fine. I put in Bounty Bob after that, and I could only go left and jump. This was true for 2 of the Wico sticks. Are they not compatible with all games? I don't remember that being the case back when I was playing it regularly. I just don't understand why all 4 directions would work on one cart and then not on the next one. Thanks for any help. Edited September 23, 2011 by ferghead Quote Link to comment Share on other sites More sharing options...
+Mitch Posted September 23, 2011 Share Posted September 23, 2011 Your 5200 console is likely slightly out of calibration. There's a small dial inside your 5200, front right corner, that controls it. Some games are very picky about the calibration, others not some much. Mitch Quote Link to comment Share on other sites More sharing options...
peedenmark7 Posted September 24, 2011 Share Posted September 24, 2011 Easiest way to calibrate it , is with missile command. a bit of playing around, but it goes fast once you know what you are looking at and for. I personally never cared for the Wico controllers for 5200, pointy stick, buttons are on the wrong side for a lefty and unlatched the stick is so sloppy... I have one for 5200 which I never use, and a new in the box one for IBM compatibles which nobody seems to want . I vastly prefer the competition pro sticks over the Wico... BIG buttons both sides which in my case being left handed I easily swapped 2 wires to properly have the fire button on the right side. the nice thing is the Y cable is built in so you can still use the factory cx52 keypad... This controller is a must for pacman & platform games. Quote Link to comment Share on other sites More sharing options...
