Hydian Posted January 9, 2003 Share Posted January 9, 2003 I just bought a 600XL and it plugs in, powers up, and plays carts, but there is no sound. I tried 2 TV's and even used different cables to eliminate that. Does anyone know what I can look at to try and fix this? Thanks. Quote Link to comment Share on other sites More sharing options...
jjessop Posted January 9, 2003 Share Posted January 9, 2003 Do you hear nothing but static or white noise? If so you lost the 4.5 mhz audio oscillator. Open it up and find the orange 4.5 mhz audio adjustment coil (depends on who made the 600xl) and next to it should be 2 silver radial polystyrene 820 pf capacitors. Gently.......but firmly, with a pair pf needle noise pliers squeeze the body of each, no I'm not joking! Your sound will now come back in 95% of all cases. The above is for an RF hookup only. If you have no static or white noise sound the 4.5 mhz oscillator is running and it's probably a dead POKEY......but doubtful. Good luck! jerry Quote Link to comment Share on other sites More sharing options...
Hydian Posted January 9, 2003 Author Share Posted January 9, 2003 No sound at all. Perfect silence. Quote Link to comment Share on other sites More sharing options...
jjessop Posted January 10, 2003 Share Posted January 10, 2003 Damn it.......a tougher problem then my friend jerry Let's see you must be going RF as a 600XL has no monitor output if I remember correctly? Quote Link to comment Share on other sites More sharing options...
Chaos Protocol Posted January 10, 2003 Share Posted January 10, 2003 600xl's RF.... Quote Link to comment Share on other sites More sharing options...
