metzger130 Posted October 29, 2011 Share Posted October 29, 2011 I got a 5200 from a friend and one of the joysticks walk down and right ONLY. You can't stop it from doing it so I had to do a little investigating. I noticed that the end of the joystick is slightly bent where the joystick goes into the port on the console. After using a meter and then looking at it, I noticed that pin 9 (common pin for BOTH pots) is not connected. Is there a way to reconnect this? Not sure if this is understandable or not. If needed I can take a picture to show better what is wrong. Thanks Quote Link to comment Share on other sites More sharing options...
bohoki Posted October 30, 2011 Share Posted October 30, 2011 if the joystick plug is bad you need to replace the whole cord since it is one piece Quote Link to comment Share on other sites More sharing options...
metzger130 Posted October 30, 2011 Author Share Posted October 30, 2011 That's what I was afraid of. I am thinking it would be better just to get a new joystick instead of trying to fix this one since I need that part and I need a new keypad since I'm missing about 4 or 5 numbers also. I'm not positive on the buttons either since I can start a game but wreck/get shocked/die however else very quickly before I can really test the buttons. With this problem though, will Best take it as a trade in or not? Quote Link to comment Share on other sites More sharing options...
Charlie_ Posted November 1, 2011 Share Posted November 1, 2011 That's what I was afraid of. I am thinking it would be better just to get a new joystick instead of trying to fix this one since I need that part and I need a new keypad since I'm missing about 4 or 5 numbers also. I'm not positive on the buttons either since I can start a game but wreck/get shocked/die however else very quickly before I can really test the buttons. With this problem though, will Best take it as a trade in or not? I have a few spare cords if you need one. Lots of keypads too. Send me a PM. You can clean your flex circuit and then super glue aluminum dots (aluminum foil hole punched) to the carbon dots on the fire buttons. Also S,P,R. Quote Link to comment Share on other sites More sharing options...
