oldjd Posted December 12, 2011 Share Posted December 12, 2011 5200/4 port,when hooked thru the switch,the power light flickers,but will not stay on. I checked the "goofy" external switch and power pack with another console and it works fine So,Im assuming its an issue in the on/off switch?Or could it be in the cord itself? Any suggestions would be welcome Quote Link to comment Share on other sites More sharing options...
phuzzed Posted December 15, 2011 Share Posted December 15, 2011 You may have a bad switchbox Typically, what I see goes wrong with the switchbox is either the voltage regulator IC goes out. Does it make a clicking sound when you plug in the power source? Another possibility could be the 5200 unit itself. There's a flip flop IC circuit chip by the power switch that I've seen go out. Another possibility could be a burned out voltage regulator. There are two of them on the board. those can be picked up at your local Radio Shack. Quote Link to comment Share on other sites More sharing options...
oldjd Posted December 15, 2011 Author Share Posted December 15, 2011 Switch box is good.Checked it with another 4 port. I think the other possibility you mentioned is the probablr cause However,I detest going to radio shack,if your not there to buy one of thier stinking phones,they ignore you But thanks for the ideas Quote Link to comment Share on other sites More sharing options...
