Ataritard Posted March 13, 2012 Author Share Posted March 13, 2012 You're welcome. Hope it works out for you. I have a new question. I'd like to do this with a table top arcade game that uses 4 C batteries. Seems to me that I can use the same adapter that outputs just over 5 volts DC, but I don't know for sure. What kind of adapter? Will a Sony 4.5 that puts out 6 volts cd no load? Or what can be used? (I should have said power supply instead of adapter.) Your Sony power supply that has an output of 6 volts dc is perfect to replace 4 AA batteries. Just put the positive and negative wires in the right place and you are golden. My question is: Will it work to replace 4 C batteries. I think I will go ahead and try it when I get a few minutes. Quote Link to comment Share on other sites More sharing options...
thegamezmaster Posted March 13, 2012 Share Posted March 13, 2012 Thanks for the info, it's very much appreciated, again thanks! Quote Link to comment Share on other sites More sharing options...
bigbee99 Posted March 13, 2012 Share Posted March 13, 2012 You're welcome. Hope it works out for you. I have a new question. I'd like to do this with a table top arcade game that uses 4 C batteries. Seems to me that I can use the same adapter that outputs just over 5 volts DC, but I don't know for sure. What kind of adapter? Will a Sony 4.5 that puts out 6 volts cd no load? Or what can be used? (I should have said power supply instead of adapter.) Your Sony power supply that has an output of 6 volts dc is perfect to replace 4 AA batteries. Just put the positive and negative wires in the right place and you are golden. My question is: Will it work to replace 4 C batteries. I think I will go ahead and try it when I get a few minutes. It will work. All batteries from AAA to D all have 1.5v. The Letter is to represent capacity. B 1 Quote Link to comment Share on other sites More sharing options...
bust3dstr8 Posted March 14, 2012 Share Posted March 14, 2012 If you want a nice clean looking setup you could install a panel mount DC jack. 1 Quote Link to comment Share on other sites More sharing options...
thegamezmaster Posted March 14, 2012 Share Posted March 14, 2012 Thanks for the help! Quote Link to comment Share on other sites More sharing options...
Ataritard Posted March 15, 2012 Author Share Posted March 15, 2012 You're welcome. Hope it works out for you. I have a new question. I'd like to do this with a table top arcade game that uses 4 C batteries. Seems to me that I can use the same adapter that outputs just over 5 volts DC, but I don't know for sure. What kind of adapter? Will a Sony 4.5 that puts out 6 volts cd no load? Or what can be used? (I should have said power supply instead of adapter.) Your Sony power supply that has an output of 6 volts dc is perfect to replace 4 AA batteries. Just put the positive and negative wires in the right place and you are golden. My question is: Will it work to replace 4 C batteries. I think I will go ahead and try it when I get a few minutes. It will work. All batteries from AAA to D all have 1.5v. The Letter is to represent capacity. B It did work. Thanks for the vote of confidence. I just got done playing a bit of Pac Man... It's all my ears could take. Quote Link to comment Share on other sites More sharing options...
thegamezmaster Posted March 15, 2012 Share Posted March 15, 2012 Glad it worked for you! Quote Link to comment Share on other sites More sharing options...
Ataritard Posted April 9, 2012 Author Share Posted April 9, 2012 This is what I've decided to do. It's fast and easy and reversible. 1 Quote Link to comment Share on other sites More sharing options...
