fernando marrin Posted January 24, 2012 Share Posted January 24, 2012 Thought my T adaptor was not working bought 2 new in the box from Best Electronics, and all i get on my video modded 2 port is a black screen has the same happened to any of you ? the mod is this: eBay Auction -- Item Number: 180799131807 i believe it's the same circuit found on the 5200 faq Quote Link to comment Share on other sites More sharing options...
OldSchoolRetroGamer Posted January 24, 2012 Share Posted January 24, 2012 By chance is your A/V modded 5200 a 4-port model? Because the first batch of the 4 port versions were not even compatible with the VCS adapter. If it's a 2 port I have no idea. Quote Link to comment Share on other sites More sharing options...
+Mitch Posted January 24, 2012 Share Posted January 24, 2012 Most 5200 video mods do not support the 2600 adapter. Mitch Quote Link to comment Share on other sites More sharing options...
fernando marrin Posted January 25, 2012 Author Share Posted January 25, 2012 It's a 2 port do you know of any av mod that does? Quote Link to comment Share on other sites More sharing options...
Charlie_ Posted January 25, 2012 Share Posted January 25, 2012 You have to use the RF output of the 5200 to use the VCS adapter Quote Link to comment Share on other sites More sharing options...
+5-11under Posted January 25, 2012 Share Posted January 25, 2012 (edited) You should be able to tap into the video output coming from the cartridge slot, no? Might require an additional video output jack, or maybe you could just tie the two lines together (2600, 5200)... or maybe not. Edited January 25, 2012 by 5-11under Quote Link to comment Share on other sites More sharing options...
low_budget Posted January 29, 2012 Share Posted January 29, 2012 Actually, I am selling the 5200 s-video mod kit on ebay, not Best Electronics. Sorry I never tested a 2600 adapter with my kit, but I will update future listings to show it is not compatible. I believe the 2600 adapter combines its video and audio into a MOD signal which goes to the RF modulator in the 5200. Getting the 2600 adaptor to work with a s-video 5200 would require modifications to the adaptor, and possibly another connector to the 5200. So while technically possible, it just wouldn't be practical. The 2600 adaptor for the 5200 is essentially a Atari 2600 without a power regulator and modulator, which are the only functions the 5200 is used for. 1 Quote Link to comment Share on other sites More sharing options...
ApolloBoy Posted January 29, 2012 Share Posted January 29, 2012 If you really wanted to, you could AV mod the 2600 adapter itself, and then just switch out the AV cords whenever you want to use it. Quote Link to comment Share on other sites More sharing options...
RangerG Posted November 24, 2013 Share Posted November 24, 2013 I don't know of any 5200 video mod that works with it. I have the older 8-bit domain one and it does not. Quote Link to comment Share on other sites More sharing options...
ApolloBoy Posted November 25, 2013 Share Posted November 25, 2013 I don't know of any 5200 video mod that works with it. I have the older 8-bit domain one and it does not.They all rely on the GTIA so none of them pass through the video and audio signals coming from the 2600 adapter. As I stated before, you'd have to perform an S-video mod on the adapter itself and then switch AV cables between the adapter and 5200. Quote Link to comment Share on other sites More sharing options...
