31336haxx0r Posted January 26, 2012 Share Posted January 26, 2012 Apart from the different connector, could a SNES controller work on a NES? Quote Link to comment Share on other sites More sharing options...
Armonigann Posted January 26, 2012 Share Posted January 26, 2012 Why? Quote Link to comment Share on other sites More sharing options...
Rex Dart Posted January 26, 2012 Share Posted January 26, 2012 You'd need to re-wire it, but it can be made to work. Quote Link to comment Share on other sites More sharing options...
31336haxx0r Posted January 26, 2012 Author Share Posted January 26, 2012 YEEEEEEEEEESSSSSSSSS!!! 8-) Quote Link to comment Share on other sites More sharing options...
Drakon Posted January 26, 2012 Share Posted January 26, 2012 I did this mod aeons ago it's pretty easy actually. The snes and nes controllers are pin compatible. Quote Link to comment Share on other sites More sharing options...
31336haxx0r Posted January 27, 2012 Author Share Posted January 27, 2012 So does it work, even though the SNES controller uses 16 bit words for communication while the NES uses only 8 bits? Quote Link to comment Share on other sites More sharing options...
Drakon Posted January 27, 2012 Share Posted January 27, 2012 (edited) So does it work, even though the SNES controller uses 16 bit words for communication while the NES uses only 8 bits? Yeah it works great I found a website where a guy explained it. I can't remember the link but if you google I'm sure you'll find it. All you need to do is open the snes cord before the plug and wire a nes plug into it. You can use a probe to figure out which wire is which pin and there's a guide that shows you which pin on the snes controller is which on the nes controller. My snes pad plays fine on both the snes and the nes. *edit* oh look what 2 seconds of google searching found... http://www.neshq.com/hardmods/snes_to_nes_controller.txt Edited January 27, 2012 by Drakon 1 Quote Link to comment Share on other sites More sharing options...
31336haxx0r Posted January 27, 2012 Author Share Posted January 27, 2012 Woah, I feel too dumb to google right now - didn't find that file. Thank you very much! Now I can start soldering. Quote Link to comment Share on other sites More sharing options...
bomberpunk Posted January 27, 2012 Share Posted January 27, 2012 hax 0n, haxx0r. 1 Quote Link to comment Share on other sites More sharing options...
Atariman Posted January 27, 2012 Share Posted January 27, 2012 The reason they both work is due to the way they shift out the data from the controller. They both send a clock signal to the controller which responds by shifting out the data bit by bit until it receives the signal to load the next set of values into its shifters. The NES will just tell the SNES controller to load before it is totally done shifting its data out. The lucky thing is that Nintendo organized the serial data the same way between both consoles! Quote Link to comment Share on other sites More sharing options...
Drakon Posted January 28, 2012 Share Posted January 28, 2012 You know....you can use a sega genesis controller on a commodore vic-20......plug and play! A lot of companies kept the same standard for controller signals. Quote Link to comment Share on other sites More sharing options...
Rockin' Kat Posted February 7, 2012 Share Posted February 7, 2012 You know....you can use a sega genesis controller on a commodore vic-20......plug and play! A lot of companies kept the same standard for controller signals. I don't know about the VIC-20, but if you do that on a C64 you run the risk of frying the keyboard/joystick I/O controllers in the Computer... Something to do with a conflict with some buttons on the keyboard and the fact that the Genesis controllers have extra circutry not found in typical controllers made for it which makes them behave a bit differently. I learned this after I wound up having to replace one of said controller ICs in my C64.... the CIA chips. Hrrmm I think I might have found a more technical explanation of the issue: This is because joysticks (which the game ports were intended to support) either pull the lines low (when active) or are an open connection (when inactive). This latter condition allows the lines to be pulled low by other sources (they keyboard for example). Sega gamepads, on the other hand, pull inactive lines HIGH. Now if you press a key on the keyboard with one of these devices plugged in, one source is pulling the line high while another I/O line (cross-connected through the keyboard) is trying to drag it down. This can put an extra strain on the CIA chip, as the circuit wasn't designed to deal with this kind of situation. Source: http://www.floodgap..../display.cgi?26 What it comes down to is Genesis controllers are not completely the same as the standard sticks the C64 was designed for, but it is possible to render a genesis controller safe to use on one. Quote Link to comment Share on other sites More sharing options...
