JonnyBritish Posted February 27, 2012 Share Posted February 27, 2012 In my code I am tracking a sprites position as a variable called AY. I wanted to add 1 to the variable so used this TurboForth code which is perfectly valid but is 5 Forth words long AY @ 1+ AY ! Here is how it works AY @ - retrieve valiable AY and store on the stack 1+ - retrieve top most cell from stack and add 1 to the value and place back on the stack AY ! - retrieve the top most value on the stack and place back in variable AY However there is a better way which is only 3 Forth words long and that is 1 AY +! From the docs at http://www.turboforth.net/language_reference.html and specifically +! value address -- S Read the cell at address, adds value to it and stores the result at address. You can see it combines all the operations into a 3 word line. same for subtraction -! value address -- S Reads the cell at address. Subtracts value from the cell value, and stores the result at address. Quote Link to comment Share on other sites More sharing options...
moulinaie Posted February 27, 2012 Share Posted February 27, 2012 However there is a better way which is only 3 Forth words long and that is 1 AY +! I worked on a FORTH version on the Atari ST with a word: 1+! so it would be AY 1+!, only two words Guillaume. Quote Link to comment Share on other sites More sharing options...
Willsy Posted February 28, 2012 Share Posted February 28, 2012 Hmmm.... Good idea... You mean like this: ASM: 1+! ( address -- ) *SP R0 MOV, \ get address in r0 R0 ** INC, \ increment the value at that address SP DECT, \ pop address ;ASM ASM: 1-! ( address -- ) *SP R0 MOV, \ get address in r0 R0 ** DEC, \ decrement the value at that address SP DECT, \ pop address ;ASM You can paste that right in to classic99 - just load block 9 first (9 LOAD) to load the assembler. Let's convert those into CODE words (so that we don't need to load the assembler every time to use them): 29 LOAD ASM>CODE 1+! CLIP ASM>CODE 1-! CLIP Here I have loaded ASM>CODE from block 29 which converts assembly words that are already in the dictionary to CODE words, and I used the device CLIP for an output device which is a classic99 only device, so ASM>CLIP will send it's output to the windows clipboard. And hey-presto, the following is in the windows clipboard: CODE: 1+! C014 0590 0644 ;CODE CODE: 1-! C014 0610 0644 ;CODE And there you go. You paste/type those into a block, and you have them forever more. Just load them when you need them! (Don't forget to add the word HEX before the CODE: word and DECIMAL at the end - I'll probably make CODE: set HEX automatically in a future version, and restore the base to the previous base at the end). So, you end up with: HEX CODE: 1+! C014 0590 0644 ;CODE CODE: 1-! C014 0610 0644 ;CODE DECIMAL Let's test them: $100 $B000 ! ok:0 $B000 1+! ok:0 $B000 @ $. 101 ok:0 $B000 1-! ok:0 $B000 @ $. 100 ok:0 Or, with a variable: VARIABLE TEST ok:0 100 TEST ! ok:0 TEST 1+! TEST @ . 101 ok:0 TEST 1-! TEST @ . 100 ok:0 Et Voilà Quote Link to comment Share on other sites More sharing options...
