+retroclouds Posted March 2, 2012 Share Posted March 2, 2012 ok, I wanna dump a block of memory to disk, using assembly language. Anyone have a reference of what DSR calls I have to use for doing that ? Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted March 2, 2012 Share Posted March 2, 2012 (edited) I believe I did a quick break-down of a utility which save chunks of memory from MiniMemory... (EDIT) Here and Here And, BTW, what is with all the broken PhotoBucket links? Do they expire after time? If so, that kinda sucks for posterity. Edited March 2, 2012 by OLD CS1 Quote Link to comment Share on other sites More sharing options...
lucien2 Posted March 2, 2012 Share Posted March 2, 2012 There is a nice exemple on page 293 of the E/A manual. You just has to change "READ" from 2 to 3 and change the "VMBR from pabbuf to buffer" by a "VMBW from buffer to pabbuf" and put that before the write operation. There is a typo: PNTR should EQUed to >8356 If you read C, you can check the source from RUSH HOUR: http://www.atariage.com/forums/topic/186797-rush-hour/page__view__findpost__p__2360340 Sometimes, it's more readable than a manual. Quote Link to comment Share on other sites More sharing options...
Stuart Posted March 2, 2012 Share Posted March 2, 2012 If you download the file ... <http://www.avjd51.dsl.pipex.com/ti/disk_images/Miscellaneous.zip> ... and extract the disk file <Miscellaneous.tidisk> from it, that contains the commented assembler source file <CART_RAM/S> for a little application to save the MiniMem RAM to disk, and to restore it again. Quote Link to comment Share on other sites More sharing options...
sometimes99er Posted March 2, 2012 Share Posted March 2, 2012 Depending on the nature and purpose of the dump, you should not forget Classic99's ability to easily make memory dumps. Enable Scroll Lock and press F10 to get a copy of CPU and VDP memory. MEMDUMP.BIN will then be 64K and VDPDUMP.BIN will be 16K plus the 8 VDP registers. Quote Link to comment Share on other sites More sharing options...
