thegamezmaster Posted April 19, 2012 Share Posted April 19, 2012 (edited) Which is a better longer lasting solution, repair or replace with a new nes 72 pin connector? Which last longer? Best place to get them new? Tried to repair a few with some success. Any thoughts or experiences? Thanks, just wondering. Edited April 19, 2012 by thegamezmaster Quote Link to comment Share on other sites More sharing options...
axh174 Posted April 19, 2012 Share Posted April 19, 2012 Since you're talking about replacing the 72 pin connector, I'm assuming you have a front-loader model. I'd recommend placing the 72 pin connector since it's rather straight-forward and replacement connectors aren't the expensive. Check out ebay (search for "NES 72 pin connector")for replacements made with a range of qualities. If you can find a gold-plated connector, that would probably work best. Prices range from $5-$15. Now, if you do have a front loader, your absolute best bet to getting rid of blinking console issues is to take your pin connector and, using a tiny jewelers flathead screwdriver, gently bend the top and bottom prongs closer to the center slot. The upshot of this is you get great, consistent results. The downside is the cartridge becomes difficult to insert and remove and you run the risk of wearing cartridge contacts down with time. Hope that helps. Quote Link to comment Share on other sites More sharing options...
thegamezmaster Posted April 20, 2012 Author Share Posted April 20, 2012 Since you're talking about replacing the 72 pin connector, I'm assuming you have a front-loader model. I'd recommend placing the 72 pin connector since it's rather straight-forward and replacement connectors aren't the expensive. Check out ebay (search for "NES 72 pin connector")for replacements made with a range of qualities. If you can find a gold-plated connector, that would probably work best. Prices range from $5-$15. Now, if you do have a front loader, your absolute best bet to getting rid of blinking console issues is to take your pin connector and, using a tiny jewelers flathead screwdriver, gently bend the top and bottom prongs closer to the center slot. The upshot of this is you get great, consistent results. The downside is the cartridge becomes difficult to insert and remove and you run the risk of wearing cartridge contacts down with time. Hope that helps. Thanks for the reply! Quote Link to comment Share on other sites More sharing options...
