keoni29 Posted April 19, 2012 Share Posted April 19, 2012 I just bought a c64, but they gave me the wrong adapter: a vic 20. Is doesn't fit in the c64, but I wonder if the juice coming out of it is suitable for a c64. Quote Link to comment Share on other sites More sharing options...
zylon Posted April 19, 2012 Share Posted April 19, 2012 no. Quote Link to comment Share on other sites More sharing options...
keoni29 Posted April 19, 2012 Author Share Posted April 19, 2012 Don't they both output 5V? Quote Link to comment Share on other sites More sharing options...
unholy Posted April 20, 2012 Share Posted April 20, 2012 From the Denial Wiki: "The power supply of the revision C is similar to the one supplied with the Commodore 64 and uses exactly the same type of connector with same pinout assingment. However, the VIC-20 model is rated for less power so it is not recommended to use a power supply from a VIC on a 64. People who accidentally or intentionally powered their 64 with the power supply of a VIC-20 revision C often damaged their 64 when the 5V regulator in the power supply failed and output excessive voltage resulting in damage to the 64's CMOS DRAM chips." Quote Link to comment Share on other sites More sharing options...
keoni29 Posted April 20, 2012 Author Share Posted April 20, 2012 Okay, I'll just have to find one (I already found one on the web, but it's brown as sh!t) Maybe I just build one myself. How hard can it be? Quote Link to comment Share on other sites More sharing options...
31336haxx0r Posted April 20, 2012 Share Posted April 20, 2012 I can't remember anymore, does the C-64 really need +5 V and 9 VAC or is the AC signal rectified to yield +12 V? If the latter is the case, you could use any brick PSU or wallwart that outputs +5 V and +12 V. Like those for USB hard disks and stuff. Quote Link to comment Share on other sites More sharing options...
unholy Posted April 20, 2012 Share Posted April 20, 2012 The 9VAC input is used for a number of things: to power the Datasette via the User Port to create +12V, +9V, and additional +5V to provide 50/60Hz signal for the TOD clock. That's for the original (breadbin) model. I understand there are some differences in how C64C handles things. In any case, it's not impossible to modify a C64 to run off +5/+12VDC (from an ATX PSU, for instance), but it is a lot of hassle. Quote Link to comment Share on other sites More sharing options...
