invisible kid Posted May 2, 2012 Share Posted May 2, 2012 eBay Auction -- Item Number: 261015388121 This is new-in-box unopened Omnimon! for Atari 400/800. This is NOT meant for use in XLs or XEs. From the Packaging: --- BEGIN --- OMNIMON! A RESIDENT MONITOR FOR THE ATARI 400/800 by David Young and Bill Williams for all programmers and ATARI enthusiasts OMNIMON! is a unique product for extending the power and convenience of your ATARI Home Computer. The OMNIMON! program resides not on disk or in a cartridge, but on a PC board which installs easily and permanently into your computer. Because it makes use of the unused $C000 page of memory, it takes up no user memory! In fact, you do not know that OMNIMON! is there until you need it and then it is always immediately available. That's right! You can interrupt, examine and manipulate any program in memory or on disk. OMNIMON! gives you complete control over your computer! You will find OMNIMON! indispensible after using it for the first time. OMNIMON! is a resident monitor which requires no user memory. It installs permanently into your computer. OMNIMON! gives you complete control over your system. Interrupt, examin and manipulate any program in memory or on disk. OMNIMON! is entered at any time by holding down OPTION or SELECT and pressing SYSTEM RESET. The current CPU state (program counter, registers and stack pointer) of the interrupted program is displayed. At this point all the facilities of the monitor are available. OMNIMON! is exited by holding down START and pressing RETURN. Many times you can return to and resume running the interrupted program as if you had never left (e.g., BASIC and DOS). OMNIMON! can aid recovery from operator errors and system glitches. It allows you to dump memory off to disk or to a printer. OMNIMON! has flexible disk I/O independent of DOS. It supports single or double density and works in sequential or linked modes. Load a DOS file or edit raw sector data! OMNIMON! has a complete set of debugging tools: display/alter memory or the 6502's registers, disassembler, search memory, single step, hex or character modes, etc. OMNIMON! is a versatile tool and very user friendly! OMNIMON! is a trademark of CDY Consulting, 421 Hanbee, Richardson, TX 75080, (214)235-2146. ATARI Home Computer and ATARI 400/800 are trademarks of ATARI, Inc. Suggested retail price: $99.95 --- END --- Quote Link to comment Share on other sites More sharing options...
fibrewire Posted May 8, 2012 Share Posted May 8, 2012 I got a few of these - I might let one go with a RAMROD board someday. 1 Quote Link to comment Share on other sites More sharing options...
invisible kid Posted May 16, 2012 Author Share Posted May 16, 2012 Found another one of these in my storage unit: eBay Auction -- Item Number: 261026015014 Thanks for looking! Oh yeah, the listing won't go live until 9:00pm eastern time, I'm not sure if it will show the item before then. Quote Link to comment Share on other sites More sharing options...
